30mm wheel spacer in the rear.
Old Feb 14, 2008 | 05:28 PM
Mamounas123's Avatar
Mamounas123
Default 30mm wheel spacer in the rear.
I currently have a 20mm spacer in the front and 25mm in the back. Im thinkin of putting the 25mm up front and putting a 30mm spacer in the back. I have stock 07 rims and i am NOT lowered. Would I need to roll the fenders?
Old Feb 14, 2008 | 05:55 PM
redlude97's Avatar
redlude97
why don't you just check and see if you have 5mm of extra clearance in the rear compared to now
Old Feb 14, 2008 | 06:21 PM
Get_Zwole's Avatar
Get_Zwole
very easy answer /thread
Old Feb 14, 2008 | 07:19 PM
SS728's Avatar
SS728
30mm will be good, nice and flush.
I currently have 25mm in the rear, I could easily go another 5-10mm.
Old Feb 14, 2008 | 08:12 PM
SniperHunter's Avatar
SniperHunter
OEM 07 rears have an offset of 33. By adding a 30mm spacer, you're left with a mere 3mm. I say that you'll rub.
Old Feb 15, 2008 | 04:40 AM
z-u-later's Avatar
z-u-later
He will not rub . . . OP is not lowered -- 25mm spacers in front & 30mm in rear with OEM rims & tires will be almost perfectly flushed with the fenders.
Old Feb 15, 2008 | 06:59 AM
cheshirecat79's Avatar
cheshirecat79
Without being lowered you will not rub.
However, id at least suggest the springmount mod in the rear to eliminate some of that fender gap. Even then, I don't think you'll rub.
Obadabot
Jun 18, 2023 11:31 PM
