Tires OK for 19'?
Old Mar 8, 2008 | 02:55 AM
whitecel's Avatar
whitecel
Default Tires OK for 19'?
Hey guys,
Just by question, I was wondering if these tires were OK to use with my 19's.
F: 225/40/19
R: 245/40/19
I used the miata.net calculator and the revs/mile were pretty close. I know these would be a little thicker on the sidewalls than if I were to go with a 35 side wall. Only reason I ask, my bro-in-law can get these tires for cheap, but can't get the 35 sidewalls for the same price. I was also thinking, since hawaii roads have such enormous potholes everywhere, it wouldn't help to have a little thicker rubber than the 35 sidewall. Is anyone running these?
Old Mar 8, 2008 | 03:15 AM
badkarma85's Avatar
badkarma85
rim widths?
Old Mar 8, 2008 | 04:26 AM
Get_Zwole's Avatar
Get_Zwole
yeah were not gonna know anything without widths look a little narrow for my taste if they are decent widths just my opinion though.
Old Mar 8, 2008 | 04:27 AM
Ziggyrama's Avatar
Ziggyrama
The differences are pretty close, within 3%, so you should be just fine. As long as the rims are not very wide, 9"+, you should be fine.
Old Mar 8, 2008 | 06:16 AM
The speedometer will read 103.75 MPH at 100 MPH.
Old Mar 8, 2008 | 09:34 AM
whitecel's Avatar
whitecel
Originally Posted by badkarma85
rim widths?
fronts are 8.5" and rear is 10"
I guess I may have a problem with the 10" rears?
Old Mar 8, 2008 | 03:50 PM
A 10 inch wheel in the back is common. Just get the right offset.
Old Mar 12, 2008 | 12:11 PM
whitecel's Avatar
whitecel
Can anyone tell me why it would be bad to run a the 245/40/19 in the rear if my rim is 10" wide? I know it would have a higher higher sidewall by about 0.3" than if I were to run a 275/35/19. Aside from the side wall, wouldn't it just look like a small stretch if you run the 245/40/19 on a 10" rear rim width?
Old Mar 12, 2008 | 12:35 PM
MethodRN's Avatar
MethodRN
For Sale
245 on a 10" wheel will not be a small stretch, granted this also depends on which tire brand you go with. But regardless it will be stretched!
Old Mar 12, 2008 | 01:05 PM
redlude97's Avatar
redlude97
on those widths, you should really be going 245/35/19 and 275/35/19
Old Mar 12, 2008 | 01:36 PM
whitecel's Avatar
whitecel
Ah ic ic. So major stretch. I thought it would be a light stretch, but if it's a stretch stretch, 275/35/19 it is.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
