Would these tires fit???
Old Jun 26, 2003 | 10:51 PM
ssk0771's Avatar
ssk0771
Default Would these tires fit???
I am thinking about changing tires on my stock rims to a wider tires.
245-40-18 in the front & 275-40-18 in the rear.
Would these fit? Does any one have them on?
Also, What is the offset on the Stock rims?
You input will be greatly appreciated.
Old Jun 27, 2003 | 08:00 AM
biscotti's Avatar
biscotti
Stock offset is +30mm. Those tires should fit fine. However, I would think twice about putting 275s on a rim that is 8 inches in width. Ideal rim width would be 9.5.
Old Jun 27, 2003 | 07:11 PM
ssk0771's Avatar
ssk0771
Thanks for your info.
Old Jun 27, 2003 | 08:19 PM
old_s13's Avatar
old_s13
Yep, most rim shops wont even install them since its a liability for them. That size tire is designed to fit a 9-11.5" wheel (you are correct, 9.5" is optimal).
Old Jun 27, 2003 | 08:39 PM
SHAQMAGIC's Avatar
SHAQMAGIC
Default New Wheels
Would 18 by 8.5 fit nicely on the stock tires for the Touring.
225 45 18
245 45 18
Thanks in advance.
Old Jun 29, 2003 | 08:54 PM
biscotti's Avatar
biscotti
Those should be fine.
ablaine
Nov 29, 2016 10:13 AM
