Offset and Tire Size/Speedometer Error calculators
Old Dec 16, 2002 | 03:07 PM
Stone Z's Avatar
Stone Z
I'll add the ones I use on a regular basis.
http://gs.tolan-hoechst.com/tirecalc.htm
http://powerdog.com/tiresize.cgi
http://www.mindspring.com/~toy4two/tire.html
Old Dec 17, 2002 | 04:53 PM
westpak's Avatar
westpak
SFZCC
Here is another
http://www.mr2.com/FORMS/tire.html
Old Jan 13, 2003 | 09:39 AM
TRACK350z's Avatar
TRACK350z
Question Wich tire does the speedo take its reading from, front or rear?
Old Jan 13, 2003 | 05:42 PM
westpak's Avatar
westpak
SFZCC
Default Re: Wich tire does the speedo take its reading from, front or rear?
It is actually the transmission which in effect makes it the rear tires which is why your speedo gets screwed up if you change sizes, the transmission is still saying the same speed as before but the car is physically going a different speed if the tires are different diameters than before.
Old Jan 15, 2003 | 06:36 AM
jelledge's Avatar
jelledge
Default Solution for Speedo Error
I am not sure if it would work on the 350Z (need to check my service manual) but there are some electronic solutions for fixing speedo error out there.
Check out this website:
http://www.blackrobotics.com/index.htm
Old Jan 19, 2003 | 02:58 PM
Intrepid's Avatar
Intrepid
Tire/Wheel Size Speedo Error Calculator
http://www.miata.net/garage/tirecalc.html
Old Jan 19, 2003 | 03:25 PM
MannishBoy's Avatar
MannishBoy
Are you sure about the transmission reading? I was pretty sure it read from the wheel sensors located at the front wheels and the outsides of the differential in the rear. These are what ABS/VDC/TC use, so I can't see why they'd use the transmission for the speedo.
Old Jan 19, 2003 | 05:57 PM
westpak's Avatar
westpak
SFZCC
I haven't checked the manual, and you are right the sensors are used for those functions so they might also be used for the speed, but either way they do not read the outside diameter of the tire so it will read the same speed as before changing tires since it will be reading at the same spot but the car will actually be going faster or slower depending on which way you go with tire size.
Old Jan 19, 2003 | 06:24 PM
MannishBoy's Avatar
MannishBoy
Right, it still measures the number of turns of the wheel, then computes speed based on a set formula.
Old Jan 25, 2003 | 10:13 PM
jran76's Avatar
jran76
Looks familar, huh?
Old Feb 17, 2003 | 02:40 PM
s2000typer's Avatar
s2000typer
Very oddly familiar.
Old Mar 24, 2003 | 06:51 PM
msink's Avatar
msink
Default Re: Offset and Tire Size/Speedometer Error calculators
Originally posted by VQracer
Offset Calculator
Not sure how accurate these are but they work for me.
Victor
That's my work. I also wrote the one on the MR2 site mentioned above. I suggest going to http://toy4two.home.mindspring.com/tirewheel.html
There is one which links you directly to tires on tirerack.
Enjoy,
Mark
Old Apr 18, 2003 | 01:00 AM
SirZaLot's Avatar
SirZaLot
So after you changed the tire/rim size, the speedo will be wrong??!!!! Any way to fix/reset it?
Old Apr 30, 2003 | 12:58 PM
Vincey2kr1's Avatar
Vincey2kr1
No one still knows were the speedometer sensor is located at. I've been trying to figure it out, I disconnected the 2 sensors located on the transmission and the speed was still being taken. They must be on the wheels? Someone has to have a manual by now
Old Jun 3, 2003 | 12:48 AM
ttheisen93's Avatar
ttheisen93
I know my base, stock is reading 1.5 mph faster than its really going, versus what my streetpilot III GPS is saying. GPS is pretty accurate (handheld reads the same in tenths as my aircraft INS/GPS combo) so I'm going with that versus my speedo. Was it because the car was designed for the 18s?
Old Jun 24, 2003 | 02:31 PM
ADMAN's Avatar
ADMAN
The "speed" is calculated in the ECU. There is a setting to switch
between 17" and 18" rim styles. The sensor is the same on all models.
If you are that confused, simply measure the circumference of your
new rim/tire and do the math for foot-distance traveled in a mile.
Geez…
Old Jun 30, 2003 | 07:18 AM
Chebosto's Avatar
Chebosto
This should be a sticky Ares!!
