19x10.5 +15 all around....will it work?
Old Mar 17, 2008 | 02:48 PM
yusoslo's Avatar
yusoslo
Default 19x10.5 +15 all around....will it work?
Enkie now has a 10.5 wide 19" rim in the RPF1 and I want to know if I can run this both front and rear on my Z. Please let me know so I can order these soon!
Plus pics of a 10.5 +15mm fitment would be great
Old Mar 17, 2008 | 03:11 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
19x10.5 +15 x 275/35 x Fender Roll = No Problem!
Old Mar 17, 2008 | 03:21 PM
yusoslo's Avatar
yusoslo
I was thinking 265 and no fender roll????
Old Mar 17, 2008 | 03:29 PM
Andy@Performance
Performance Nissan
It can work, how much camber are you running?
Old Mar 17, 2008 | 04:46 PM
yusoslo's Avatar
yusoslo
alot!!!
Old Mar 17, 2008 | 04:48 PM
Andy@Performance
Performance Nissan
alot!!!
You should be fine than.
Old Mar 17, 2008 | 06:01 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
WOw~
Old Mar 17, 2008 | 06:11 PM
DustinZ33's Avatar
DustinZ33
I would still roll anyway. You should have the room in the rear but you could either correct some camber or use a spacer in the rear with some camber correction.
Old Mar 17, 2008 | 07:51 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
i'm big fan of RPF1
if i get another set that will be RPF1
Old Mar 18, 2008 | 04:37 AM
yusoslo's Avatar
yusoslo
RPF1 was my first wheel choice, then I debated for 6 months even looking at the most expensive wheels there where and the RPF1 still won out when price was no object.
But I will be getting a set in a special finish that no one in the country has...literally, I contacted Enkei and they said I would have the first set
Old Mar 18, 2008 | 01:22 PM
cbr900son's Avatar
cbr900son
Get DustinZ33 to post pics of his car.
Old Mar 18, 2008 | 01:40 PM
yusoslo's Avatar
yusoslo
i have seen his, they are 18's and he is using spacers to create a +0 offset up front i believe.
When you go with the 10.5" +15 you get the concave face so thats why i want them all around
Old Mar 18, 2008 | 02:11 PM
DustinZ33's Avatar
DustinZ33
I have 18 x 10.5 +15 F and +0 on the rear.
I thought the rpf1 only came in 19x10, not 19x10.5?
Old Mar 19, 2008 | 04:24 AM
yusoslo's Avatar
yusoslo
well i called Enkei and they told me other wise, I thought so too from looking online.
Old Mar 19, 2008 | 05:25 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
even a 265 on a 10.5 can potentially rub. The only way to know if it will rub on your car is to try it. My 265/30 RT615 on cr kai 18x9.5 +12 rubbed horribly with even up to 3 degrees of camber
The RPF1 only go to 19x10 +22. The 10.5 +15 is in 18 inch, not made in 19 inch
http://www.enkei.co.jp/jp/products/w...ion/index.html
Old Mar 19, 2008 | 10:35 AM
Shift-350's Avatar
Shift-350
yes the 19s are only made in a 10" wide wheel, and they only come in a +22 offset, nothing less. Yes they'll fit, it'll fit nicely in teh front but be a bit weak in the back.
I run the 18x10.5 (+15) all aroudn for autoX/track setup with a 285/30 v710 with a fender roll and I get no rub. And Im pretty low.
pics of my track/autoX setup:
http://shaqdiesel.smugmug.com/galler...LFxq#263425918
- nlzmo400r
Old Mar 19, 2008 | 11:51 AM
07JimmyZ's Avatar
07JimmyZ
Damn....that thing looks like a monster truck! lower it!
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
