New Tires = Traction Control Porblem
Old Mar 24, 2008 | 07:25 PM
Originally Posted by Sprayed
I believe that I have the 06 enthusiast so I don't believe that I do. Only TCS.
Then your problem is unique. Tire height is generally a VDC not a TCS problem. Keep in mind that new tires are slippery especially in corners.
Are you certain that the correct wheels are on the correct axle?
And that the same size tires are on the same axle?
Will be interested in the solution.
Old Mar 24, 2008 | 07:29 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Originally Posted by teh215
I would be willing to bet that the tire sizes are incorrect proportionally front to rear...
+1
Old Mar 24, 2008 | 07:56 PM
Spike100's Avatar
Spike100
David,
I think your (above) post may confuse the issue. We have already established that Sprayed’s rear tires are too short (too small an overall diameter). I don’t understand why you post a comparison to 225/45-18” tires since these are what he has on the front, and nothing to do with why his rears are too short (except that maybe you are doing a front to rear comparison). Sprayed’s front tires (225/45-18”) are the correct size (for overall diameter).
You seem to believe that it is always VDC that causes problems with incorrectly sized tires.
Having owned and driven a 2003 Enthusiast model Z, I can say that TCS by itself can activate SLIP when the car has the wrong sized tires. It isn’t just VDC equipped-Z’s where this happens. I only mention this since you constantly ask if the car has VDC.
--Spike
Old Mar 24, 2008 | 08:09 PM
Originally Posted by Spike100
David,
--Spike
Thanks for the clarification.
Old Mar 24, 2008 | 08:30 PM
Spike100's Avatar
Spike100
That’s it?... All you have to say?
You’re the teacher and I’m the student… I was bracing for a thorough thrashing… and then nothing.
I cannot think other than this is not going to go well for me… I hate it when you act nice.
--Spike
Old Mar 25, 2008 | 05:06 AM
lowrider's Avatar
lowrider
This is what I needed to hear. I will take these numbers to the shop tomorrow. Thx
OK - 275/40/18 is too wide for your stock 8.5" rear wheel. A 265/40/18 will be OK, but please go no wider. A 245/40/18 up front will be just fine. Using those two sizes will keep VDC happy, maintain the proper front to rear stagger, and give you the wider tire your looking for.
Lou
Old Mar 25, 2008 | 06:11 AM
--Spike
LOL. There is a difference between the operation of VDC and the operation of TCS. But this is not the place for a debate. As long as we get Sprayed fixed that’s all that counts.
Old Mar 25, 2008 | 08:58 AM
Sprayed's Avatar
Sprayed
No worries. I went back today and told them what all of you were telling me. They had no problem with finding 4 new Toyos for me. 245/40/18 for the front and 255/40/18 for the back. Hit a couple of hard corners and had no slippage. You guys were a life saver. I will definitely do my homework in the future and seek these boards for help and advice. Thanks again.
Old Mar 25, 2008 | 09:11 AM
3m wol8's Avatar
3m wol8
glad to see you got your problem figured out.. what part of Ohio are you in?
Old Mar 25, 2008 | 10:01 AM
UMW350Z's Avatar
UMW350Z
I used to work at a tire shop, I was the only educated one there that knew my stuff. When a car came in and wanted to switch sizes, it was easy to dissaude them from making a dumb and expensive mistake from just buying whatever they 'thought would fit'.
It's a good thing the shop took care of you, all of the plus size application I was not 100% sure about, i made the customer and my manager sign a waiver which basically made the customer look crazy for attempting something nobody was sure about! This stopped more than a couple people from messing up their car and themselves
Old Mar 25, 2008 | 11:15 AM
We know some stuff around here. If we don’t we just make it up.
Old Mar 25, 2008 | 11:16 AM
Sprayed's Avatar
Sprayed
Cincinnati
Old Mar 25, 2008 | 02:34 PM
The Brickyard Rat's Avatar
The Brickyard Rat
davidv's specialty is reviving the dead (threads that is).
Old Mar 25, 2008 | 03:52 PM
Spike100's Avatar
Spike100
David,
I apologize… I looked at the chart that you posted and now realize that your point was that Sprayed’s original (problematic) rear tires were actually shorter (overall diameter) than his fronts. Of course that will result in erratic TCS deployment.
I’m going to go with the “senior moment” for my excuse on missing this one. Sorry for the confusion.
--Spike
Old Mar 25, 2008 | 04:14 PM
Spike100's Avatar
Spike100
Sprayed
Glad to hear you got this fixed. I think you are really going to like the 245/40-18” tires on the front. When I went with this front size, I was surprised at how much better the car handled with neutral-steer and more responsive turn-in.
I’m also curious if you notice any feeling of improved acceleration since your rears (255/40-18”) are within OEM specifications, but slightly shorter (about ½” shorter overall diameter than stock).
Drive these new tires for a day or two, and then please report back on this (your) thread with any impressions.
Subscribing…
--Spike
Old Mar 25, 2008 | 08:00 PM
David,
--Spike
Its cool. TCS and VDC and ABS is a complicated system. We are all learning.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
