19x10 +40 rear offset how bad would it look
Old Mar 30, 2008 | 06:07 AM
THe Emperor's Avatar
THe Emperor
Default 19x10 +40 rear offset how bad would it look
As the topic says how bad would a rear 19x10 +40 offset look?
Old Mar 30, 2008 | 07:43 AM
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Lightbulb Offset wise...
it's going to look pretty bad or "tucked," and this is prior to what type of wheels we are actually talking about. Run a quick search in the wheel and tires area. Most Zs are running something in the 20+ offset range. You may want to look for something of this nature. Good luck.
Old Mar 30, 2008 | 08:08 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
itll stick out about .5" further then a stock 8.5 + 33 wheel, a lot of people on stock get 25mm or 1" spacers.
Itll look better then stock, but not optimal.
Old Mar 30, 2008 | 09:16 AM
THe Emperor
So is it possible to use spacers to make it stick out more?
Old Mar 30, 2008 | 09:43 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
you can use spacers,but your not getting the proper offset/lip/spoke design.
Old Mar 30, 2008 | 09:55 AM
THe Emperor
If I did go with spacers which size would you suggest?
Old Mar 30, 2008 | 01:27 PM
You have been a member for 8 months. Time to start using an offset calculator.
350z82
Oct 1, 2015 06:25 PM
