OZ 3 Piece wheels
Old Apr 11, 2008 | 06:32 AM
jdf28045's Avatar
jdf28045
Default OZ 3 Piece wheels
I was looking at a set of 3 Piece OZ Wheels (Galileo III) but I don’t see any information on this forum about OZ. Anyone had any experience with them? Good, bad? Also looking for recommendations if any one has ever order 3 piece rims and what sizes for a stock 05 body. Would like to go wide but not have to worry about rub. Looking at 18" rims maybe 19". Car is not lowered. May be dropped about an inch in the future. The seller is saying that I need the width of the inner rim and the width of the outer rim. Any help would be great. Thanks.
Old Apr 11, 2008 | 07:18 AM
AbsolutSpeedZ's Avatar
AbsolutSpeedZ
I found them on www.tirerack.com...here are the stats:
FRONT:
19x8 (2.0 inch lip)
Offset: 27mm
Bolt Pattern: 5-114
Rec. Tire Size: 225/40-19
Weight: 28.4lbs.
19x8.5 (1.5 inch lip)
Offset: 33mm
Bolt Pattern: 5-114
Weight: 29.3lbs.
REAR:
19x10 (2.5 inch lip)
Offset: 40mm
Bolt Pattern: 5-114
Rec. Tire Size: 245/40-19
**Lightweight: 29.8lbs.**
19x10 (3.0 inch lip)
Offset: 27mm
Bolt Pattern: 5-114
**Lightweight: 29.6lbs.**
IMO, seems like the offset is too high.
Old Apr 11, 2008 | 07:30 AM
AroundMyHorn's Avatar
AroundMyHorn
offsets blow, keep trying.
Old Apr 11, 2008 | 07:31 AM
Z04's Avatar
Z04
so do those wheels. maybe that is why no one has them on a Z
Old Apr 11, 2008 | 07:46 AM
JETPILOT's Avatar
JETPILOT
30 lbs is lightweight?!?!?!?!?! Really bad width and offsets too.
JET
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
