To roll or to shave - that is the question
Old May 6, 2008 | 09:52 AM
LAKERSFAN's Avatar
LAKERSFAN
Default To roll or to shave - that is the question
Refering to rolling or shaving the rear fender for aggressive wheel/suspension set-ups.
Wanted to find out what the pro's/con's are for each.
Is this just a personal preference?
Is one better than the other?
Please post opinions/experiences.
(Didnt know if i should start this in the wheel or suspension section.)
EDIT: Maybe need to clarify. Im not asking if i need to or not. i know i do. i just want to find out if theres any advantages/disadvantages to either method.
Old May 6, 2008 | 09:58 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
Old May 6, 2008 | 10:00 AM
Z04's Avatar
Z04
neither is better. how about setting the car up right the first time with the proper size wheels/tires and not doing something like that in the first place?
Old May 6, 2008 | 10:12 AM
LAKERSFAN's Avatar
LAKERSFAN
how is my car not setup right?
when you run a 285/35 on a 19x10.5 wheel, you have to do one or the other......
thanks for the great posts there people.
Idwin, seriously, can you stop being a tool for maybe one day?
Old May 6, 2008 | 10:14 AM
hershell's Avatar
hershell
I rolled my rear fenders when I had the bodykit installed. I'm running Volk GT-7
20x10.5 + 24 offset in the rear and 19x9.5 front +30 offset
I didn't want to take a chance on having any problems so I just went a head and had it done. Rolling was the easiest.
Old May 6, 2008 | 10:16 AM
LAKERSFAN's Avatar
LAKERSFAN
thanks for a decent response, hershell.
just curious if theres any advantages, disadvantages to either method.
Old May 6, 2008 | 10:17 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Roll. I have a 20X10 w/ 275/35 and a 20mm spacer. It puts my offsets at +17. I have a "mild" roll with no rubbing whatsoever.
Old May 6, 2008 | 10:18 AM
bluezup's Avatar
bluezup
what offsets you running? i had to roll mine. only rubbed when hitting a bump.
running 19x9.5 +12 275/35 in the rear.
Old May 6, 2008 | 10:22 AM
LAKERSFAN's Avatar
LAKERSFAN
running 19x10.5 +17 offset with 285/35/19 tires.
am rubbing a good bit which i figured i would going with this size tire.
actually had the 275/35 before and got no rubbing what so ever but im on the nismo suspension so its a pretty mild drop.
just seeing if there are any advantages/disadvantages with either method or if its just a personal preference.
Old May 6, 2008 | 10:24 AM
ARMSTRONGARMS
rolling = possiblity of cracking paint
cutting = reduced strength and poss for corrosion/rust.
Old May 6, 2008 | 10:25 AM
Crom's Avatar
Crom
You shou'd try running 275/30's ...it'll give a slightly stretched look but should solve your issues...might need a mild roll...
Old May 6, 2008 | 10:30 AM
gothchick's Avatar
gothchick
I have 285/30/19 on 19x10 +30 offset. No rolling, cutting, pulling, or dry humping neccessary. :-)
Old May 6, 2008 | 10:31 AM
phreaktor's Avatar
phreaktor
Design Engineer
Cutting your fenders would leave no perpendicular support. Someone could lean on your fender and dent it, lol..
Old May 6, 2008 | 10:33 AM
hershell's Avatar
hershell
Both are going to weaken the fenders. The inside lip on the fender is for strength as well as the row of spot welds on the inside fender lip, both strengthen the fender. If you shave the fender you are going to lose these welds and some of the strength, it can cause waves in the fender. With rolling you are just folding the fender lip up. It will weaken the finder a little, but less than shaving it. I’m sure there are some body shops out there that can recreate the lip, but you are talking money. You can rent the tool to roll the fender yourself for a lot less. If I was going to add Veilside III fender flares or Do-Luck fender I might consider shaving, other than that I would roll the fender. Hope this helps.
Old May 6, 2008 | 10:34 AM
Crom's Avatar
Crom
Got a pic ?
Old May 6, 2008 | 10:36 AM
gothchick's Avatar
gothchick
I'll post some up after work~ :-)
Old May 6, 2008 | 10:40 AM
LAKERSFAN's Avatar
LAKERSFAN
thanks for the responses everyone!
sounds like rolling is the way to go.
i know i can run a 275/35 with no problems, but like the look of the 285 better.
now i just need to find someone who will do it soon. lol
i know theres someone very local who does this, but he isnt available for a couple weeks.
Old May 6, 2008 | 10:48 AM
dutchboy350Z
Finally some go
Just find someone that takes there time and doesn't rush anything. If they don't periodically use a heat gun in between rolling do NOT let them touch your fenders.
Alberto did mine in less than 40 minutes. No cracking at all.
Old May 6, 2008 | 10:57 AM
Crom's Avatar
Crom
Daytona350 (Anthony) did mine..and my left fender is even all bondo'ed up..no cracking what so ever....
Old May 6, 2008 | 10:58 AM
LAKERSFAN's Avatar
LAKERSFAN
unfortunately he isnt available for the next couple weeks due to finals.......
