how dangerous is 50 psi on stock tire?
Old Jun 25, 2008 | 08:59 PM
VO...'s Avatar
VO...
Administrator
Originally Posted by DavesZ#3
It's not as dangerous as it appears. The max PSI rating for the Potenza RE050 is about 50-51 psi anyway. That's at the max PSI at max load of 1400lbs per tire. That means that you'd have to have the Z and contents weigh 5600lbs to get each tire to it's max rated weight. You were well under the max condition.
I bet it rode like hell though.
Here's where your concern should be - I'd bet that the tech at the dealership read the max psi rating from the sidewall rather than lookup the correct tire pressure from the manual or door jamb plaque. I'd call the service adviser at the dealership and make them aware of the problem.
Excellent tid bit of info Dave.
The other day I was servicing my GF's car. Specs called for 32psi all the way around. Three tires were on the money, one had 48psi. Bad tech FTL...
Old Jul 13, 2008 | 07:17 PM
j.arnaldo's Avatar
j.arnaldo
Oldsnail: When you do let out some of the excess air out, do it while the tires
are COLD. That applies when adding air to them, also.
Old Aug 12, 2008 | 09:10 PM
fordslowcus's Avatar
fordslowcus
rock hard tires= max fuel milage goodness! you should tip the tech. hehe j/k
Old Aug 13, 2008 | 09:42 PM
kd07z's Avatar
kd07z
working in a dealership i have seen as much as 90 psi in one mini van. it sometimes takes 120 psi to mount the tire on the rim. so its ok but i wold still drop it down because it can change your alignment.
Old Aug 14, 2008 | 04:43 PM
B1nKs's Avatar
B1nKs
Originally Posted by fabcas311
[IMG][/IMG]
LMFAO ! This **** had me rolling.
Old Aug 15, 2008 | 07:20 AM
TopNotch's Avatar
TopNotch
i run my fronts at 47psi warm, and the rears 45psi warm, never had any problems, i run this all the time. The only problem that i can see is the tire wear with neg camber appears more apparent. Better gas milage, better handling, all good things. Anyone who says otherwise is a nancy.
Old Aug 15, 2008 | 09:20 AM
DavesZ#3's Avatar
DavesZ#3
47psi - that's gotta feel like riding on wagon wheels.
Better handling? It's got to be bouncing over the top of bumps and ripples in the road. In a turn, I can easily imagine it skittering off the road.
Old Aug 17, 2008 | 04:51 PM
TopNotch's Avatar
TopNotch
if it were skittering off the road do you think i would keep running my tire pressure at that psi? It's not bad at all in my opinion. i've autocrossed it at that psi, ran great times, held great in the corners.
Old Aug 18, 2008 | 05:06 PM
R350nate's Avatar
R350nate
they should all be 35psi or slightly below 35 psi. thats the best traction/tire wear and imo thats what matters when it comes to tires.
