Rims made for widebody kits
Old Jun 21, 2008 | 01:24 PM
vannguyen's Avatar
vannguyen
Unhappy Rims made for widebody kits
I need help my 350z base model is getting a veilside 3 wide body kit put on it!
do I need bigger rims or to put spacers on? Because it won't look right with rims being tucked underneath I need the rims to stick out a little more!
Old Jun 21, 2008 | 01:27 PM
Moroccan_Mole's Avatar
Moroccan_Mole
you're going to need a wheel with custom offsets or very large spacers.
Old Jun 21, 2008 | 01:32 PM
z350boy's Avatar
z350boy
Based on your post count I will assume you are a "noob". You will need to have the rims flush with the body to get the maximum effect from the bodykit.
IMO a new set of wheels with offsets that sit flush are the best way to go. First off you get to choose a set of wheels to compliment the boy work you have done to the car.*Secondly you can get offsets that will work.
As an option, especially if money is an issue is to get wheel spacers. Be aware that spacers will put additional stress on your wheel bearings and suspension, however if you get a quality set and don't get extreme with the size you can get by just fine.
If you have to go larger than 10MM I would say don't do it. I am very weary about spacers and so have not used them, but I don't want to be overly biased against them. Hope this helps...and GOOD LUCK!!!
BTW: Post pics when you are done, it's alaways good to see what people are doing to their ride.
Old Jun 21, 2008 | 02:22 PM
JETPILOT's Avatar
JETPILOT
20mm spacers are no big deal. But your should look into custom wheels like Forgeline, kinesis, or HRE. They can custom make any wheel width offset combo you would like.
Old Jun 21, 2008 | 03:24 PM
terrasmak's Avatar
Get ready to drop $4k min. in wheels.
Justin100
Nov 25, 2021 06:26 AM
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
