Wondering if theese wheels would work.....
Old Jun 22, 2008 | 03:45 AM
Musto's Avatar
Musto
Default Wondering if theese wheels would work.....
Theyre 17x8, but the offset is +40mm.... it says it will work for 350z's, but im wondering if it will look right with that offset?
Old Jun 22, 2008 | 04:00 AM
SchismX's Avatar
SchismX
They will fit a Z alright and look very ugly at the same time. Those wheels will tuck way inside the fender. With an 8 in wide rim you will need an offset of about +10 while having the car lowered at the same time to make it look good imo. The car would look better if you went up to 18s and a little more width. Then use 17s to track with.
Old Jun 22, 2008 | 04:42 AM
Musto's Avatar
Musto
Originally Posted by Zman636
They will fit a Z alright and look very ugly at the same time. Those wheels wheel tuck way inside the fender. With an 8 in wide rim you will need an offset of about +10 while having the car lowered at the same time to make it look good imo. The car would look better if you went up to 18s and a little more width. Then use 17s to track with.
well what are the offset of the factory 17s?
Old Jun 22, 2008 | 05:55 AM
Z04's Avatar
Z04
+30 front (17 x 7.5) and +33 rear (17 x 8)
Old Jun 22, 2008 | 07:34 AM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
