Which put more wear on tire?
Old Jul 1, 2008 | 10:43 AM
UY350Z's Avatar
UY350Z
Default Which put more wear on tire?
HI, i was just wondering if camber, or toe that will put more wear on tire. As of right now im debating to put a camber kit on the rear of my car, but if i do im gonna have to roll my fender which im tying to void. I am currently running le-37 and spec are 19x91/2, and 19x101/2 +22 all around. wrap with toyo t1r 275, and 245 in the back. Thanks
Old Jul 1, 2008 | 10:49 AM
stein's Avatar
stein
"Toe is the most important wheel alignment angle because it has the greatest effect on tire wear"
http://www.aa1car.com/library/wheel_alignment.htm
Old Jul 1, 2008 | 10:50 AM
Thermal1's Avatar
Thermal1
Toe kills tires - camber does too, but not as much.
Old Jul 1, 2008 | 11:34 AM
UY350Z's Avatar
UY350Z
Thanks for the quick reply.
Old Jul 1, 2008 | 06:49 PM
You have a 245 mm tire on a 9.5 inch wheel, and a 275 mm tire on a 10.5 inch wheel. Which means you are riding on the sidewalls and destroying the tires. Not sure why you are even concerned about alignment and tread life.
Old Jul 1, 2008 | 07:18 PM
Spike100's Avatar
Spike100
^^ I'm not sure about this (what I am proposing)...
But certainly 245mm on a 9.5" wheel and 275mm on a 10.5" wheel is stretched, but members here have done this with good results.
I would think psi is vital for this setup. I believe a careful psi setting allows the tread to lay flat (even with a stetched tire) for normal wear and good performance.
Please correct my post if I am wrong here.
--Spike
Old Aug 3, 2008 | 10:51 AM
35oZephyR's Avatar
35oZephyR
In a nutshell:
Wrong Camber= uneven tire wear. Mostly to the inside of the wheel or outside. Moderation is ok.
Wrong Toe = excessive scrubbing of the wheel in the wrong direction...you are just burning rubber off.
ablaine
Nov 29, 2016 10:13 AM
