Mounting stock tires that has TPS
Old Jul 5, 2008 | 08:59 PM
tractng's Avatar
tractng
Default Mounting stock tires that has TPS
Guys,
I might swap my rear tires. Any shop can do this without a problem? Would the TPS be difficult to work with?
Thanks,
Tony
Old Jul 5, 2008 | 09:40 PM
SlowCoupe's Avatar
SlowCoupe
Originally Posted by tractng
Guys,
Thanks,
Tony
not at all. just tell them not to break the bead of the old tires by the valve stems.
Old Jul 5, 2008 | 11:20 PM
Eddie@Performance's Avatar
Eddie@Performance
Performance Nissan
What kind of problem are you thinking of? if you are switching wheel positions that will cause a tire warning light. If you are just cross rotating tires just make sure the wheel is in the same location. As for tire beading, its not much of a issue, just dont use tire iron against the casing.
Old Jul 8, 2008 | 11:20 PM
tractng's Avatar
tractng
Eddie,
I have a slow leak. Is under warranty?
The tires look fine. My guess is around the valve. Can any shop handle this?
I was thinking of swapping the tires just as alternative (might somehow fix it).
Tony
Old Jul 9, 2008 | 08:24 AM
Eddie@Performance
Performance Nissan
Eddie,
Tony
Aftermarket wheels no, OEM wheels maybe. Youll have to check with Tim if its covered. Best way to find out where its coming from is th dunk the wheel in a tub of water.
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
