Offset Question
Old Jul 15, 2008 | 10:14 PM
performwheels's Avatar
performwheels
Default Offset Question
I have a set of MSR Wheels 20X8.5 front, 20X10 rear both have 40 mm offset. I was wondering if these would sit flush with the fenders or will they sit in a little bit. Should I buy spacers since it is a high offset, because I want the wheels to stick out a bit. Thanks for your help guys
Old Jul 15, 2008 | 10:16 PM
OffsetZ33's Avatar
OffsetZ33
They will sit in. I suggest spacers - at least 20mm f and r
Old Jul 15, 2008 | 10:24 PM
performwheels
Thanks
Old Jul 16, 2008 | 07:18 AM
Use an offset calculator and compare the current wheels with the new wheels. With a tape, check if you clear the strut housing, brake caliper and fender.
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Jul 17, 2008 | 07:34 AM
performwheels
I don't know what the current wheel dimensions are exactly. They are the 18 inch stock that came with 2007 Enthusiast. I was thinking 25 mm spacers in the rear and 20 mm up front
Old Jul 17, 2008 | 04:22 PM
MDNJPN's Avatar
MDNJPN
My TSW 20's are an offset of 20mm on the front and they set even with the fenders, the back ones are an offset of 40mm and they set way in, I am going to get spacers for the rear ones, but like you I dont know what size to get with a 20x10 and a 285/30.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
