275 tire in the front
It can be done with a 5 or 10 mm spacer, but not a 9.5 +30.
This is a 18X9 +30 with a 275 tire. Your wheel will be 6mm closer to the upright. Can't do it without at least a 5mm spacer.
Istan had +35 on the front of his with 275/35-18 and it fit fine. Tires were Falken 452's. The rim will clear , but the actual tire shape could be a factor.
Jet that pic is a 275/40 up front, you can read the 40 part on the tire.
sorry to sound really noobish, but what are the benefits of running such a wide diameter in the front (aside from being more flush with the fender)? what would you rears be (305 or more)?
i have 18X9 (+32) in the front and am running 245/40/18. wouldn't the wider tires mess with the VDC/traction control and speedometer?
VDC/TCS problems have to do with tire height not width. The 275/35 and your 245/40 have the same height, so VDC doesn't know the difference. The benifits other than looks, it reduces understeer depending on your rear tire choice/lets you run a wider rear tire without adding more understeer.
so does anyone have an 18x9.5 +20 with -1.4 degrees camber and a 275/35/18 in the front? dropped on Hotchkis.... just wondering how well this would work.. will be dropped on Espelir soon though (.4")
