spacer or not??
i currently have work emotion cr-kai now...
spec are 18x8.5F and 18x9.5R offset+20
i dont think this set up is aggressive enough....can the spacer make it looks more aggressive......??? thanks in advance!!!
The only aggressive mod is lots of carbon fiber and stickers. That will surely put fear in the hearts of mankind and small animals.
so i should put on 10mm spacer in the front and 15mm spacer in the rear??
again, my rims are emotion cr-kai and specs are 18x8.5F +22 offset and 18x9.5R +20 offset....if i put those spacers on, do i need to rolled fender??
I say not since it's gonna make minimal difference.
When I had spacers on my old set of wheels, I always had a fear that the bolts might shear off when I was doing heavy track work.
Also, you'll be adding plenty of unsprung weight.
the size of the spacer subtracts from the offset so:
you have +20 offset
10mm spacer will make that:
20-10 = +10 offset
or 15mm spacer:
20-15 = +5 offset.
you can just take a tape measure and measure how much farther out you want your wheels.
you have +20 offset
20-10 = +10 offset
or 15mm spacer:
20-15 = +5 offset.
I think mild spacers are okay (5mm~15mm). But going over board on it (20mm +) defeats the purpose of handling, stability, longevity of bearings, stud fatigue, etc, imho.
Ichiba, H&R, Project Kics are quality spacers.
no, do not bow to peer pressure or the fad of putting spacers on a car that does not need them. if you wheels are the proper offset, there is no need to use these at all.
FromGtoZ
Sep 20, 2015 03:41 PM
