FIVE:AD Wheels
Old Jul 10, 2009 | 06:38 AM
  #181
Vertex350's Avatar
Vertex350
Originally Posted by wmousawi
pm me for
Price for GunMetal shipped to 16803
19x9.5 +22
19x10.5 +22
need them in those specs ASAP pleaseeee
Andy does not work for Performance Nissan anymore. U can either call them direct or use one of the wheel vendors for a quote. Thanks.
Old Jul 22, 2009 | 09:43 PM
  #182
wmousawi's Avatar
wmousawi
Default Just bought the Five AD and Need help
Alright guys I just got the Five AD S5 Wheels in those specs
Front 19" x 9.5 with 25 offset
Rear 19" x 10.5 with 22 offset
I really need help with tire sizes. with those wide wheels which set would be a better choice for an 07 350z with the vdc
i see most people go with
F: 245/35/19 and R: 275/35/19
would that look too stretched out or is it the perfect choice?
i think people also use
F: 255/35/19 and R: 285/35/19
I need the best setup with no vdc problems. will not track the car. running stock suspension right now. fenders are not rolled.
Please help me choose the right size. I appreciate all inputs. Thanks guys
Old Jul 22, 2009 | 10:02 PM
  #183
knils's Avatar
knils
275 is the perfect choice in the rear I believe, the sidewall on the 285/35 is too chunky IMHO... for the front I think 245 or 255, depending on how you want your sidewall to sit.
Old Jul 22, 2009 | 10:09 PM
  #184
2k6-z33's Avatar
2k6-z33
245/35/19 and 275/30/19 if you don't want to roll your fenders.
Old Jul 22, 2009 | 10:24 PM
  #185
MethodRN's Avatar
MethodRN
For Sale
With stock suspension you don't need to worry about any rubbing issues even with the 255/285 set-up.
You'll need to consider tire brands don't always run the same widths even though that brand x and brand y have 285/35/19 sizes. I know from personal experience that 285/35 BFG KDW2 on a 10.5 width wheel was perfect. Granted the BFG tends to run wider than some other brands.
Also consider, since you're on stock suspension, 245/275 would probably accentuate the larger vender gap.
Either set-up should work with no VSD issues though.
Old Jul 22, 2009 | 10:55 PM
  #186
wmousawi's Avatar
wmousawi
so are you saying that the 245/275 will make the gap look bigger? is it going to be looking worse than stock wheels?
second question in your honest opinions which setup should i go with?
can someone check if the sizes are within the 3% diameter difference. I did that based on the calculator but which one is the best based on anybody's experience.
Old Jul 23, 2009 | 12:15 AM
  #187
SageZ's Avatar
SageZ
vdc is no concern. The 245/275 looks better (especially when lowered) But remember the 255/285 provide a little more protection for your wheels and more rubber always feels better.When I was faced with this decision, I chose 275 because I thought 285 looked too chunky. What do you think?
Old Jul 23, 2009 | 05:39 AM
  #188
Thermal1's Avatar
Thermal1
all 4 sizes you picked are fine and won't mess with the vdc.
You could even do 245/35F and 285/35R if you wanted to
or 255/35F and 275/35R
Old Jul 23, 2009 | 06:05 AM
  #189
lgear080's Avatar
lgear080
245 up front or you'll be unhappy with the look!!!
Old Jul 23, 2009 | 09:42 AM
  #190
wmousawi's Avatar
wmousawi
alright guys i really appreciate the help i am gonna go with the 245/275 as I have seen that setup alot and i am planning to lower it so this will keep me on the safe side.
can someone help me decide which brand to buy?
yokohama
Hankook
Falken
i want toyo proxes but too expensive for now so can someone help me choose one of those.. thnx alot
Old Jul 23, 2009 | 09:45 AM
  #191
TheOtherRob's Avatar
TheOtherRob
Cant go wrong with Falken's. I am running the Nitto Invo's and like them so far. Cut down on road noise alot from the Neo Gens.
Old Jul 23, 2009 | 02:46 PM
  #192
terrasmak's Avatar
+1 i've run both tires, and i suggest the 255/35 front with the 275 or 285 rears. Less gap and you don't want to add uny more unneeded understeer to you car.
Old Jul 23, 2009 | 03:16 PM
  #193
TheOtherRob
^ One thing I would like to add is that I believe the Invo's side walls are pretty tall. They almost look like 285's (I have 275).
Old Jul 23, 2009 | 06:42 PM
  #194
black_03's Avatar
black_03
What susp are you gonna run?
Old Jul 23, 2009 | 06:50 PM
  #195
knils's Avatar
knils
hankook s1 evos are nice and on closeout over at tirerack
Old Jul 23, 2009 | 08:50 PM
  #196
wmousawi's Avatar
wmousawi
so wait 255/35 and what about the profile size on the rears should I do 30 or 35? can you give me profiles for all front and rear. dont wanna get into the over 3% thing.
can you further explain on the understeer? which setup would add more to that? thanks man
Old Jul 24, 2009 | 03:32 AM
  #197
Nick-VTR's Avatar
Nick-VTR
255/35/19 on front
285/35/19 on back
too chunky? Don't think so.
edit: i'm on stock suspension btw.
Attached Thumbnails FIVE:AD Wheels-dscn4788.jpg   FIVE:AD Wheels-dscn4789.jpg   FIVE:AD Wheels-dscn4960.jpg
Old Jul 24, 2009 | 03:10 PM
  #198
wmousawi's Avatar
wmousawi
alright I really like this setup.. did you have to roll your fenders? any vdc or traction problems? is this a correct setup for a 350z (i mean is it within the 3% diameter difference?)...
Cant make my mind anymore im so confused and the wheels just laying down in the boxes... so shud i go 245/35/19 275/35/19 or 255/35/19 285/35/19???
Old Jul 24, 2009 | 06:16 PM
  #199
Nick-VTR's Avatar
Nick-VTR
go 255/35/19 285/35/19
Use the tire caclulator and compare to your stock wheels if you are worried. However, it is within 3% and won't cause any issues with VDC. My wheels are 19x9 and 19x10, so the tires will look even more stretched on your wheels as they are slightly wider.
You will probably have to roll the rear fenders (even if you go 275) with 10.5 +22.
Old Jul 24, 2009 | 10:22 PM
  #200
wmousawi's Avatar
wmousawi
all right i guess im gonna go with the 255/35/19 285/35/19
how much do they do the fender rolling for usually? and any suggestions on tire brands for those sizes?
