18x10.5 +22 upfront?
Old Oct 2, 2008 | 12:36 PM
QuicksilverZ33's Avatar
QuicksilverZ33
Default 18x10.5 +22 upfront?
I am currently running TE37's 18x9.5 +22 245/40 front
18x10.5 +22 275/35 rear
I hate understeer.
Anyone running a square setup consisting of 18x10.5 + 22 all around? Im looking to pick up two more 10.5's for the front...and run 285/275 all around if possible....anyone have comments about fitment of this setup up front?
Thanks
Old Oct 2, 2008 | 01:15 PM
JETPILOT's Avatar
JETPILOT
I have a 9" +22 up front, and I am lowered about 1.5" and have -2.5 camber. It's very close to rubbing on the outside. VER VERY close. I'd have to vote no on the 10.5" +22 with a 275 in the front.
Old Oct 2, 2008 | 04:43 PM
rramos28's Avatar
rramos28
I am running 18x10.5 +15 in the front with 265/35 and I dont rub. I think 275 will fit fine.
Old Oct 2, 2008 | 06:00 PM
gregom's Avatar
gregom
I'd put 275's or 265's on the 9.5 fronts. I'm running 265 on a 9.5 front with +30 mm offset and I have about 7 mm of clearance before rubbing.
I'd also put 295's on the rear if it were me, the wider the better.
Old Oct 3, 2008 | 02:19 AM
terrasmak's Avatar
275/30's should fit no prob on your front wheels, and sway bars will also help even more.
Old Oct 3, 2008 | 02:31 AM
4thHorse's Avatar
4thHorse
What parts do you have on your car, there are cheaper ways to get rid of understeer.
Old Oct 3, 2008 | 08:42 AM
SIN3's Avatar
SIN3
it does fit but you need to camber the car some more in the front with camber arms and change tire size. i played around with this on my old TE37 time attacks
this is what will work
265.30.19 +22 -3.5 camber (around)
275.35.19 +22 -3 camber
the rear can go 285.35.19 but you will have a bigger side wall in the rear and will look funny compared to the fronts. the 275/35 is better.
doet.
Old Oct 3, 2008 | 03:37 PM
QuicksilverZ33
Sry I forgot to list mods...Im running hotchkis sways on med(f and r) and lowered on sportlines(1.2 inches) w/ stock shocks....I use rt615s now but there shot so its time for new tires anayway...looking at dunlops...
I was hoping to get away with a 285/30 all around but i'll settle for 275's
thanks for the replies
Old Oct 3, 2008 | 07:24 PM
DustinZ33's Avatar
DustinZ33
I'm also running 18x10.5 +15 F with 265/35 RT615s. I currently have -2.5 degrees camber up front and I'm dropped on Stance. Have about 2.5" drop. No rubbing. 275/35 might rub without going more negative with the camber but you have +22 so it should be fine. 285/30 You would need more drop and more negative camber. My front fenders are now pulled a little from autox and a drift event. With only a 1.2" drop, I don't know how you'll be able to look at the wheel gap.
Old Oct 3, 2008 | 10:05 PM
06platinumG's Avatar
06platinumG
If your just trying to get rid of the understeer just change your sways to soft in front and stiff in rear and you should be good
Old Oct 3, 2008 | 10:07 PM
Triple8Sol's Avatar
Triple8Sol
You should be fine, as long as you don't have Brembos.
Old Oct 5, 2008 | 04:17 PM
QuicksilverZ33
?....i have stoptechs...
Old Oct 5, 2008 | 04:30 PM
TheShaddix's Avatar
TheShaddix
i have -2.5 camber and running 265/30/19 on a 9.5 rim with +7 offset. No rubbing (kinda).
Old Oct 6, 2008 | 12:35 PM
SIN3's Avatar
SIN3
DOET!
Old Oct 6, 2008 | 01:07 PM
polish pete's Avatar
polish pete
sorry to hi-jack but i guess you can fit the stock grand touring rims in the front. the 19x10's? its only a 30 offset.
Old Oct 7, 2008 | 09:44 AM
monies's Avatar
monies
i have 19x8.5 +22 in front
edit: 235/35/19f x 275/35/19r
Old Oct 8, 2008 | 04:48 PM
prstriker04's Avatar
prstriker04
i dont know about 10.5 in front i run a 19x10 in front with 25offset and a 245/35 tire. =/ lowered on gf210s
Old Oct 12, 2008 | 02:01 PM
QuicksilverZ33
The reason why I am intersted in going with 10.5 front and rear, with the same tires size, is so I can rotate them...
If Im not mistaken...doesn't the M-Works 350Z run 10.5 all around with 285/30/18 ?
Old Oct 15, 2008 | 04:48 AM
z-u-later's Avatar
z-u-later
Aren't your 245 tires stretched quite a bit on 10" wide rims? Pics please.
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
