will this fit...... (VERY AGGRESSIVE)
Old Oct 7, 2008 | 12:25 PM
amg55driver's Avatar
amg55driver
Default will this fit...... (VERY AGGRESSIVE)
19x10+21 19x11.5+17
with some stretch tires on stock body 350z conv. with rolled fender?
Also, tire size recomendation will be appriciated.
thanks
-John Kim
Old Oct 7, 2008 | 01:18 PM
lgear080's Avatar
lgear080
I don;t think this setup will even require a fender roll. perhaps in the rear.
I;m going to say 245/275 35 series 19"
What Wheels MANG?
Let's see installed!
Old Oct 7, 2008 | 05:45 PM
jdmrwd's Avatar
jdmrwd
watch out for the offset police... LOL
you will get flamed by them.
Should post this on the aggressive wheel thread.
Old Oct 7, 2008 | 05:58 PM
TacoMadre's Avatar
TacoMadre
Those offsets are fairly conservative
Old Oct 7, 2008 | 06:14 PM
JETPILOT's Avatar
JETPILOT
Depends what you consider "to fit".
Old Oct 7, 2008 | 07:09 PM
amg55driver
this means i dont even need camber adjustments? (a-arms and rear camber bolts)?
will lowered coilover camber will make it fit?
Old Oct 7, 2008 | 07:35 PM
nipponpower's Avatar
nipponpower
Originally Posted by amg55driver
19x10+21 19x11.5+17
thanks
-John Kim
it should fit fine, like someone posted a 275, should give you a nice stretch on the rear, im 235/35/19 on the fronts with 10 wide. gives a nice stretch but i rub a little cause of my offset, but with a +21 you will be fine. i would roll them just to be safe.
Old Oct 10, 2008 | 05:28 AM
amg55driver
so if i do 255/35/19, on front would it be too wide??
Old Oct 10, 2008 | 10:51 AM
LaZeEbOi177's Avatar
LaZeEbOi177
If its not hella flush, it doesn't fit.
your setup is semi agressive, but I guess that setup is fine if you do not want to do the camber kit and other stuff.
Old Oct 10, 2008 | 11:21 AM
amg55driver
so should i order a set of 15mm or 20mm spacers for front? or both font and rear?
watchathink?
Old Oct 10, 2008 | 02:38 PM
Ilike350Z's Avatar
Ilike350Z
r u serious, spacers? NO! unless you those wheels to stick even farther out.
Old Oct 11, 2008 | 09:08 AM
prstriker04's Avatar
prstriker04
na bro you're fine in the fronts i run 19x10 with 24offset infront my tire is 245/35 no rubbing or any adjustments
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
FromGtoZ
Sep 20, 2015 03:41 PM
hardkicks
Sep 20, 2015 12:28 PM
