I need help with Rim & Tire sizes!!!
Old Aug 10, 2003 | 05:18 PM
TIGHT-Z's Avatar
TIGHT-Z
Arrow I need help with Rim & Tire sizes!!!
I am going with 19" wheels because I want looks and performance. I was also thinking about either 275 or 265 for the rear tires and 245 for the fronts.
My question is, I dont know about all the offsets and things like that, and I was wondering if someone can look at my setup and help me with what I want to do. Like how do I know if some rims will fit the tires I am getting.
Old Aug 10, 2003 | 05:33 PM
Stone Z's Avatar
Stone Z
To keep your tire setup as close to staock as possible in 19's you should run 245/35 and 275/35 front and rear respectively.
A 245/35 can be put on a rim anywhere from 8-9.5 inches in width.
A 275/35 can be put on a rim anywhere from 9-11 inches in width.
The stock offset for the Z is as follows
17's 30mm front and rear
18's (non Track) 30mm front and rear
18's (Track) 30mm front & 33mm rear
Most people think the stock wheels sit too far in the fender well and want their aftermarket wheels pushed out a bit, so they go with lower offsets. Anything from 20-30mm should be good. Just remember. The wider the wheel gets the higher your offset can be.
Here's a good tool to use in order to determine the correct offset.
http://toy4two.home.mindspring.com/offset.html
sales@czp
Sep 23, 2019 03:30 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
