hubcentric rings
Old Oct 10, 2008 | 07:38 AM
bswanny's Avatar
bswanny
Default hubcentric rings
Probably a dumb question but how do you know when you need hubcentric rings? Would you know? Thank you for any help
Old Oct 10, 2008 | 10:22 AM
JETPILOT's Avatar
JETPILOT
When you mount the wheels if the wheel does not sit on the hub then you need a hub centric ring. The center of the wheel should fit precisely on the hub.
Old Oct 10, 2008 | 10:23 AM
thezcarguy's Avatar
thezcarguy
I had a vibration in my steering wheel about about 60mph. Just like a tire out of balance.
Old Oct 10, 2008 | 12:10 PM
sry110's Avatar
sry110
Jetpilot gets the prize for most correct and succinct answer.
Your OEM wheels are hubcentric. Loosen the lug nuts and jack up the car. Even though the lugnuts are loose the wheel will remain concentric with your axle.
In the case of the Z, the wheel hub outer diameter is 66.1 mm. If you have a wheel whose center bore is larger than 66.1 mm, then you will need hub centering rings.
Old Oct 14, 2008 | 06:22 AM
HockeyZ39's Avatar
HockeyZ39
So if your putting spacers on stock rims, no need for the hubcentric?
Old Oct 14, 2008 | 08:41 AM
sry110's Avatar
sry110
Depends on the thickness of the spacer. If the spacer thickness exceeds the height of the 66.1 mm diameter wheel hub, then the wheel would have nothing to center on.
Old Oct 14, 2008 | 12:01 PM
bswanny's Avatar
bswanny
So would it be correct to assume that running wheels that need a hubcentric ring without a ring, would cause the axles to fail prematurely?
Old Oct 14, 2008 | 01:45 PM
HockeyZ39's Avatar
HockeyZ39
So as long as the spacer is less than 66mm no hubcentric ring is needed?
Just want to be 100% certain.
Old Oct 14, 2008 | 06:11 PM
sry110's Avatar
sry110
Wrong. If the thickness of the spacer exceeds the height of the wheel hub (the portion that is 66.1 mm in diameter, which is the part that engages into the bore of the OEM wheel), then you will need hubcentric spacers.
Old Oct 14, 2008 | 06:13 PM
Kwame's Avatar
Kwame
No, not at all.
Old Oct 14, 2008 | 06:20 PM
JETPILOT's Avatar
JETPILOT
Wrong. You want the center of the spacer to hubcentric even if it does not completely cover the full thickness hub. It's the only way to make sure the spacer is centered on the hub.
But then again here is Lou Gigliotti's American LeMans race car and check the spacer he is running....
Old Oct 14, 2008 | 06:34 PM
Kwame's Avatar
Kwame
By the way I just want to state that hubcentric rings are not a MUST. They are simply an aid in helping you center the wheel on the hub. It is very possible to mount an aftermarket wheel centered upon the vehicles hub without hubcentric rings. I will definitely agree that it helps when mounting a wheel, but both Adam (Work Wheels) and I (Volk Wheels) have run wheels on our Zs without hubcentric rings for tens of thousands of miles without any issues whatsoever.
Old Oct 14, 2008 | 06:36 PM
JETPILOT's Avatar
JETPILOT
Agreed.... all wheels are lug centric today. If tightened in the right order hubcentric rings are redundant. But for the price I'll take a set for free insurance.
Old Dec 14, 2008 | 12:56 PM
kevin1533's Avatar
kevin1533
since we're on the topic of centric hub rings...
I recently bought a aftermarket rim for my car without the hub rings. well i drove the car for about 2 blocks before I heard clanking. Basically what happened was my bolts took alot of the force apparently... many of them were loose when I checked.
I measured my hub bore and it was around 57mm and the rims measured at 70mm.
I know this sounds like a dumb question. But would this have been avoided if I had used the hub rings or is there a defect in the wheel? (reason I ask is b/c most of you said there shouldnt be a problem without the rings)
Thank you in advance everyone.
regards,
Kevin
lolwatbro
Oct 9, 2021 04:58 AM
bcoffee20
Nov 19, 2015 06:39 PM
abarclay
Wheels Tires
Sep 21, 2015 04:51 AM
