Agressive offsets
Old Oct 24, 2008 | 11:30 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
my friend put 305x30x19 in the rear but he had to roll his fenders
Old Oct 24, 2008 | 12:40 PM
Kwame's Avatar
Kwame
Originally Posted by OldDirty Z33
This is what I stated before but still doing massive research before I start ordering parts:
What I'm thinking about is a set up of maybe 15 to 10mm in the rear and a 5 to 10mm up front with possibly 255/40/18 all around but I would like to put the biggest tire I can fit in the rear but at the same time I don't want like how the front tires would have a different look then the rears due to the tire differences.
Also BloMyS14 is running RPF-1 18x10.5 +15 Front 18x10.5 +0 Rear Kumho V710 285/30/18 Front and Rear
I believe I could pull off a 10mm in rear and 5mm up front with 40 tires with fender rolled. If I do go bigger I think I have to go with a 35 tire and drop the car some more.
If you look at the pictures and the type of tire he is running I think that will explain to you why he is able to fit those on his car. Those sidewalls are extremely thin, and that tire looks to run on the narrow side. Not to mention you have no idea what his camber specs are.
Old Oct 24, 2008 | 12:42 PM
OldDirty Z33's Avatar
OldDirty Z33
Thats what I said read it my quote again bro. I'm not worried about the front camber but only the rear. I will be buying my own camber kit and doing adjustments myself.
Old Oct 24, 2008 | 12:44 PM
OldDirty Z33
Also hes a 10.5 wide rim, if it was smaller he could fit a bigger tire with a little lift of the cars suspension. I'm running 9.5 a whole inch smaller but it does make a huge difference.
Well any ways this is the set up I will be doing. (If I can fit it.) I'm looking for the stiffest rear shocks for my Z that money can buy.
Tanabe GF210
Rota P45r +20 around 18X9.5 5mm spacer up front 10mm in the rear= +15 up front +10 in the rear.
Goodyear eagle F1 255/40or35/ all around
I will go from there and see how it will look
Old Oct 24, 2008 | 01:12 PM
Kwame's Avatar
Kwame
I'm not sure what it is that you are trying to accomplish. I also believe our definitions of what constitutes a "wide" tire is different. In any case. good luck to you.
Old Oct 24, 2008 | 04:01 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
Here Ya Go.... This more what your looking for?
I have since switched tires to 255/40F and 295/35R
Old Oct 28, 2008 | 11:36 AM
scotts300's Avatar
scotts300
I run 305/30/19 rears on a 10.5" wheel and haven't touched the fenders. It easily fits with the right offset wheel. Stock camber.
Old Oct 28, 2008 | 11:41 AM
scotts300's Avatar
scotts300
So after the fender roll and pull, you can fit the 295 w/o rubbing? Still at stock camber and height?
Old Oct 28, 2008 | 11:51 AM
2005daytonaZ's Avatar
2005daytonaZ
I don't want aggressive stretched tires. That's not the style. Reading is your friend.
i know how to read...there are examples of aggressive wheels in that thread..not just stretched tires. G/L finding a solution though...i'm wanting to put spacers on my nismos some day.
Old Oct 28, 2008 | 07:25 PM
OldDirty Z33
What kind of shops would roll fenders.???? Body shop or just some performance shops?
Old Oct 29, 2008 | 01:49 AM
ekidd's Avatar
ekidd
theres a dude on here that rolls fenders in the 818. Just search for "fender rolling in the 818" or something like that. Also, check out zilvia.net, theres a couple reputable guys on there that roll fenders in socal.
Old Oct 29, 2008 | 06:39 AM
OldDirty Z33
Cool thanks bro
Old Oct 29, 2008 | 08:09 AM
deviljon's Avatar
deviljon
also check daytona350z (anthony), he does it over in newport beach. his schedule is always packed though, so you're gonna have to PM him asap.
Old Oct 29, 2008 | 02:08 PM
Busted*Shox's Avatar
Busted*Shox
interesting
Old Oct 29, 2008 | 03:45 PM
OldDirty Z33
^ lol
Old Oct 29, 2008 | 09:26 PM
CKY881's Avatar
CKY881
How much did you lower?
seagrasser
Oct 11, 2015 03:27 PM
etong
Sep 10, 2015 06:14 PM
