Lookin for drop car post
Old Nov 9, 2008 | 06:03 PM
beast66's Avatar
beast66
Default Lookin for drop car post
Where can i find it the only one i find it how low can you go and that is too low. Is there any 1.0-1.2 inch drops. I have searched I just havent found any. Someone help me out and send me the link. Thanks
Old Nov 9, 2008 | 07:43 PM
beast66's Avatar
beast66
any posts on that??
Old Nov 9, 2008 | 07:49 PM
Zridder19's Avatar
Zridder19
Allmost every lowering spring for a Z is around that range. I think you need to do a bit more searching....
Old Nov 9, 2008 | 07:51 PM
beast66's Avatar
beast66
the only post ive seen are ones that are slammed.. im looking for normal drops
Old Nov 9, 2008 | 07:59 PM
Zridder19's Avatar
Zridder19
d00de you have been here as long as I have and you dont know about this car yet? Like I said search and you will find EXACTY what you want.
Again, almost EVERY drop for a Z, is EXACTLY in the range you are looking at.
Old Nov 9, 2008 | 09:09 PM
finalforce's Avatar
finalforce
^ very true. If you notice on that particular thread that shows slammed Z's, only a handful of them "truly" qualify.
Instead of flaming you let me give you a very simple tip to save your name here on this forum. If you don't find what your looking for in a search, go to the media section or whathaveyou, and look at some member builds. PM those who have what you are looking for and more than likely they will be more than happy to give you pointers. I get quite a few PM's and I'm always open to guide fellow forum members to the best of my knowledge. If I don't have the answer, 99% of the time I know someone here that does.
So next time, before you start a thread, please use the resources available to you by other innovative means That way you make a friend rather than have people spit on you over the Internet. It doesn't look like they are now, but depending on how fast the mods allow this to go on before they delete this, it will only get worse.
Old Nov 9, 2008 | 09:27 PM
finalforce's Avatar
finalforce
.....oops my bad, here's my advice. With a drop of 1" or 1.2", it is very conservative and you will hardly have issues on the road as long as you don't have a lip/body kit. Springs will probably fit your needs unless you plan on tracking it and want more options for adjustability. Your front camber will barely if not, be affected. The rear will have a very small negative change, but your factory OEM toe/camber bolts can be adjusted and do the job for you. If you go lower, you will need an aftermarket camber kit. Since your preference is only for about an inch drop, we won't really need to cover further details on a lower drop
If you ever decide to go lower PM me and I will go over it will you in detail.
Old Nov 9, 2008 | 09:51 PM
No one have ever stretched the tires, set up some serious negative camber and lowered the car 1.2 inches.
You would be the first.
Chris350z03
Oct 8, 2023 07:19 PM
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
Juztin
Nov 22, 2015 07:03 AM
Bigsyke
Sep 11, 2015 06:19 PM
