305/35/18 PROXES R888 On A 18X10 +35
Old Nov 17, 2008 | 05:22 PM
JETPILOT's Avatar
JETPILOT
Originally Posted by DRIFT
Hey Jet
Looking good as always.
Can you please comment on this set-up for the R888's:
Volk GTS 19x9.5f +17 19x10.5r +18
Toyo R888 R-Compounds 235/35/19f 295/30/19r
My main question is how will the handling be with only a 235 up front?
Any concern about traction control and are the offsets right?
As you know there are not alot of options for the R888's in 19"
Thanks in advance for the help.
No one ever really agrees with my wheel fitments so I try to refrain from commenting in public anymore. In my opinion the 235/295 stagger is too much to be overcome with suspension adjustment. Not to mention the lack of grip on the front end. I'd go with an 18" wheel up frotn and get the 265 or 275.
Old Nov 17, 2008 | 05:47 PM
DRIFT's Avatar
DRIFT
All LASER LASIK
Thanks for the insight. Ill have to see if I can get the wheels I want in different sizes.
Old Nov 19, 2008 | 06:22 AM
Motormouth's Avatar
Motormouth
a 235 on the front with a 295 on the rear? woah man.
Old Nov 19, 2008 | 06:31 AM
Motormouth's Avatar
Motormouth
Originally Posted by JETPILOT
Like I said the reason they look oversized is beacuse their is no rim protection strip which would fill out the sidewall. Toyo specs for the 305/35/18 is 10"-12". My whels are 10".
My tire/wheel combo isn't a fashion ensemble and I don't do things because they look good or bad. This a car that only sees the track. I don't care how they look. I turned a 2:22 at Sebring, and the car has alot more in it. I suck as a driver. This car is likely capable of a 2:05.
I wasn't speaking of aesthetics. I was speaking of handling characteristics of an over-sized tread compared to the rim size. If you are fitting it onto the smallest recommended rim width, I always thought that this setup caused sloppiness in the tire.
You are working with some great guys I think (Champion) and I am sure you discussed all of that, I was just surprised. But no rim bead protection would make up for that tread size
speaking of that, who developed your suspension setup? did you have help picking tire sizes and ride heights and all of that or was this all by yourself?
Old Nov 19, 2008 | 10:08 AM
z-u-later's Avatar
z-u-later
Toyo R888 R-Compounds 235/35/19f 295/30/19r.
Perfect setup for 1/4-mile drag racing . . .
Old Nov 19, 2008 | 10:49 AM
JETPILOT's Avatar
JETPILOT
I have no slop induced by the tire/rim combination. The R888 has a very stiff sidewall. The car reacts instantly and precisely to steering wheel inputs. There was no change in feel moving from a 295/30/19 on a 10" wheel to a 305/35/18 on a 10" wheel.
I set up my own suspension. Alot of it was done by trial and error on the track. Suspension geometry was calculated on a computer program. While the front roll center isn't ideal right now it's a good compromise that I can live with until I install some roll center adjusters that work.
I didn't have the money to custom order a set of $4000 wheels which is what this car needs. Perfect situation would be a 12" +35 for the rear which no one manufactures. An 11" +35 would b a compromise, but no one makes that either. This was my only option and I'm very happy with it.
Pictures are pictures. Seeing the car in person is a different story. The tires don't bulge that much. The tire is a racing tire and has a very wide/round shoulder. If you have a 305 summer tire that had minimal clearance and installed these R888's they would never fit. All sizes of R888's are very wide for their measured tread width.
Old Nov 19, 2008 | 11:07 AM
Motormouth's Avatar
Motormouth
didn't moonface just put out some fairly cheap roll center adjusters?
Old Nov 19, 2008 | 11:13 AM
JETPILOT's Avatar
JETPILOT
You call $500 cheap?!?! No one seems to know how these work. I am waiting for a response from Adam @ Z1Auto. He was supposed to be in contact with Moonface to get an explanation. My suspension program says there is no way they can work. Still waiting for a response. Jury is out on that. Maybe there is something I am missing.
Old Nov 19, 2008 | 12:14 PM
Motormouth's Avatar
Motormouth
is there an alternative way to achieve a change in the roll center on a lowered car?
if could you fabricate/modify something, what would the cost be?
Old Nov 19, 2008 | 02:49 PM
guitman32's Avatar
guitman32
Jet, no issues with slight rubbing from sidewall flex under high lateral loads?
Thanks for sharing your setup, btw.
Old Nov 19, 2008 | 03:18 PM
JETPILOT's Avatar
JETPILOT
No... there is no rubbing whatsoever on the inside or outside. I had this setup on the track @ Sebring already. Perfect fit!
Old Nov 19, 2008 | 03:29 PM
Ghost_shift's Avatar
Ghost_shift
I have seen this setup in person. The car looks incredible!!
But the best part is the blue lugnut in each wheel. Now I have to do it to mine!!
Old Nov 19, 2008 | 04:01 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
Only thing I don't like is how thick the sidewall is. The R888 is a great tire, but when are tire companies going to learn to make more sizes????
The 305/35 is too thick IMO, but a 30 series would be nice. Then they have the 285/30 and 295/30 which would be amazing in a 35 series.
Maybe im too picky but a 265/35f and 285/35r would be an amazing setup. I have had it with the REO1A's. Sticky tire, but the sidewalls were MUSH and felt very unstable. The handling was great though, no oversteer or understeer.
Guess i'll just have to go 275/35f and 295/35r Kuhmo MX. I think the 295/35 is boarderline thick, but it'll do.
Sorry about the mini rant, love the tire, just wish there were more sizes available.
Old Nov 19, 2008 | 04:09 PM
JETPILOT's Avatar
JETPILOT
Thanks Miguel! You can run a single blue lug nut if you want.... BUT NEVER tell people why I do it!
The 275/35/18 F 305/35/18 R are the exact OEM tire diameter. It was perfect for me becasue I think those little donut tires that are smaller than OE diameter look rediculous with big wheel wells. I wanted OEM diameter.
This a a car that only sees the track so.... I don't care about the looks. But in my opinion it looks hot as hell. It's got a racecar look. No one who is serious runs 19's on the track.
With 565 whp I don't want to change the gear ratio with smaller tires making traction even worse.
Old Nov 19, 2008 | 08:53 PM
guitman32's Avatar
guitman32
Thanks!
bcoffee20
Nov 19, 2015 06:39 PM
azndoc
Wheels Tires
Oct 10, 2015 02:59 PM
lolsupfoo
Sep 9, 2015 12:57 PM
Jeff@Evolution
Nov 30, 2004 10:39 AM
