18" Nismo wheels available (question)
Old 08-24-2003, 03:13 PM
Apexi350z
Charter Member #50
Apexi350z's Avatar
I was going to get the Bronze, but after thinking about it, it won't look that clean on a silver car. I think I will stay with silver.
will the stock TPS fit? It should right since it's NISMO?
Old 08-24-2003, 03:25 PM
FLY BY Z
FLY BY Z's Avatar
TPS fits. I am getting the silver ones very soon... Anyone want my Touring rims with tires???
Old 08-24-2003, 03:47 PM
Apexi350z
Charter Member #50
Apexi350z's Avatar
Mr. Potato Head, I also have Eibach springs, do you think the rear will extend out too much that it will rub the tires?
do you think the stock 245/45/18 will be okay with these wheels for now?
Old 08-24-2003, 05:01 PM
FLY BY Z
FLY BY Z's Avatar
I think everything will be ok. Also, Nissan "recommends" the S Tune Suspension be used with these wheels. It lowers it some too. The Nismos have a 30mm offset in the rear like stock so they will be pushed out 19mm in the rear. I think it will be ok. Could you measure the available distance when you get a chance? I can't find my ruler... The fronts will be pushed out 11mm.
Old 08-24-2003, 05:21 PM
Apexi350z
Charter Member #50
Apexi350z's Avatar
on my car, there's about 14mm between the outer edge of the tire and the inner edge of the inside fender.
I think you said okay, but I just want to make sure 245/45/18 can be mounted okay on 18x9.5" wheel?
Old 08-24-2003, 06:36 PM
zwindsor
Twisty addict
zwindsor's Avatar
Default Re: Center Caps & Tire Pressure Sensors ?
Originally posted by grutter
Are center caps included ? Available ??? Additional cost ?
Do the Tire Pressure sensors fit ?
Center caps come with them and are included in the price. Yes the TPS's fit just like stock.
Old 08-24-2003, 06:38 PM
zwindsor
Twisty addict
zwindsor's Avatar
There should be no rubbing with the Eibachs and the stock tires will fit.
Old 08-24-2003, 06:44 PM
Apexi350z
Charter Member #50
Apexi350z's Avatar
Here are a few things that I like about the Nismo LM-GT4:
1. authentic rims just for the 350z (no replica I know of)
2. 18lbs / wheel!
3. stock tps will fit
4. can still use stock tires now with larger tires possible later on.
5. polished lips (even though not as much as others)
6. did I mentioned NISMO?
Thanks guys!
Old 08-24-2003, 06:58 PM
zwindsor
Twisty addict
zwindsor's Avatar
2. 18lbs / wheel!
Thanks guys!
These are the same reasons (excuses ) I'm using to warrant spending the money I know I shouldn't
Old 08-24-2003, 08:03 PM
FLY BY Z
FLY BY Z's Avatar
The rears are 9.5 inches wide and the tire size recommded is a 275. You can stretch a 245 that far?
Old 08-25-2003, 07:07 AM
Jeff@Performance
Performance Nissan
Jeff@Performance's Avatar
I just talked to our tire company. They said the 245 will fit the front, but but running the 225/245 combo may lead to trouble. In a hard corner you might debead the tire from the rim.
Old 08-25-2003, 09:45 AM
Topics II
Topics II's Avatar
I've been drifting on my 245/40/18 es100's on 18x10 rear rims for 2 events now, running 30psi (cold) and doing 70-80mph slides. All is well, so im ordering 2 more pairs for the rear now, since those guys didnt last much more than 3 hours.
Old 08-25-2003, 10:10 AM
Jeff@Performance
Performance Nissan
Well that pretty much say's it all!!
Old 08-28-2003, 12:42 PM
myinfinitig20
myinfinitig20's Avatar
any news about some black nismo lmgt4 and another question...are these the same rims as the te37? They look identical
Old 08-28-2003, 01:41 PM
Jeff@Performance
Performance Nissan
Haven't heard anything from Nissan on the Black. And as far as the te37 goes, I'm not yet familiar with that rim. This is still a learning experiance for me. I'm sure someone on the Forum woill have your answer though.
Old 08-28-2003, 01:45 PM
Audito350Z
Audito350Z's Avatar
TE37 is a 6-spoke wheel... the NISMO wheel is a 5-spoke. But, I think they both are manufactured by Mackin Industries (Ray's Engineering, VOLK). That is why they look similar.
For what it's worth... the Track model 350Z wheels are a variation of the TE37.
PeteH
Old 08-28-2003, 01:48 PM
Jeff@Performance
Performance Nissan
PeteH
Thank you!! A day doesn't go by that I don't learn something from someone here!
Old 08-28-2003, 03:11 PM
  #38
Apexi350z
Charter Member #50
Apexi350z's Avatar
PeteH
Actually I believe Mackin Industries is just the US Distributor, all the wheels are mfg. by Rays Engineering.
Read more from here: http://www.mackinindustries.com/rays.html
Old 08-28-2003, 03:32 PM
  #39
350Now
350Now's Avatar
This is correct Mackin Industries is the US Distributor of the Rays line of wheel which include the Volk Racing.
Old 08-28-2003, 03:33 PM
  #40
350Now
350Now's Avatar
Hi Jeff,
Any news on 19s for the Nismo LMGT4?
Jeff
Quick Reply: 18" Nismo wheels available (question)
