Question Regarding ET Radials
Old Nov 25, 2008 | 08:12 PM
original786's Avatar
original786
Default Question Regarding ET Radials
Hey...I want to buy some Mickey Thompson ET radials...I was wondering if 305/35/18 fit the Z.
I have the Works Emotion XD9 wheels with the +45 offset in the rear. Do you guys think the 305 will fit without sticking out?
Old Nov 25, 2008 | 10:02 PM
thawk408's Avatar
thawk408
I run a 18x10.5 +28 rear with a 305/35/18 nitto drag. I had to roll my fenders some to keep from rubbing and im lowered on hotchkis springs. Isnt the work wheel only a 9.5? I would suggest looking for something smaller, if you are not putting down serious HP.
But to answer your question, I think they would clear the fender, but probably not the shock tower, unless you get a 15mm or so spacer. A pic of the rear would help me give you more information tho.
Old Nov 26, 2008 | 04:58 AM
original786
I am new at this...How do u put up a photo if I have it saved on desktop?
Old Nov 26, 2008 | 06:10 AM
thawk408's Avatar
thawk408
Click "Go Advanced" below the bottom textbox. Then scroll down and click "Manage Attachments".
Old Nov 26, 2008 | 08:35 AM
original786
Thanks...Here are pics...Hope they help
Btw...I am running 275 right now
Attached Thumbnails Question Regarding ET Radials-backdrop.jpg   Question Regarding ET Radials-side.jpg   Question Regarding ET Radials-back.jpg   Question Regarding ET Radials-exhaust.jpg   Question Regarding ET Radials-front.jpg
Old Nov 26, 2008 | 08:37 AM
original786
Here are some more!
I know these wont help..but just for funn..haha
Attached Thumbnails Question Regarding ET Radials-drift.jpg   Question Regarding ET Radials-fence.jpg
Old Nov 26, 2008 | 09:09 AM
thawk408's Avatar
thawk408
Why offset are the rear wheels? Why do you want the mickey so bad?
Old Nov 26, 2008 | 09:59 AM
original786
I just want some traction..I am putting down 577 at 14psi...with 550 torque...Anyway I can traction would be great. Right now I have BF goodridge and it catches in 3rd gear.
In the rear...ofset is +45.
Ive heard that MIckey is the way to go to get more traction...
Old Nov 26, 2008 | 10:18 AM
bighungrydewees's Avatar
bighungrydewees
I'm running BFG radials on 17x9's (22mm) when I go to the track and I'm happy with them if you decided to stay with 275's. You have ALOT more hp though.
Here's some pics to help you decide:
Attached Thumbnails Question Regarding ET Radials-drag-pics-008.jpg   Question Regarding ET Radials-drag-pics-005.jpg   Question Regarding ET Radials-drag-pics-007.jpg
Old Nov 26, 2008 | 11:00 AM
scotts300's Avatar
scotts300
What is your wheel width? The +45 should be good to stuff a large tire on there, but you shouldn't put too large a tire for a given wheel diameter. I run a 305 on a 10.5" rear +43 wheel without one suspension tweak.
On my Z32TT, I run a 295/35/18 BFG DR, which gives decent traction in 2nd gear (~650rwhp).
Old Nov 26, 2008 | 01:09 PM
thawk408's Avatar
thawk408
What width is the wheel? Mickey one of the best, but they will not last long. The Nitto DR gives the most treadlife, with the BFG being second, but the BFGs hook better then Nitto.
Old Nov 26, 2008 | 04:43 PM
original786
The rear is 18x10". Are they good enough diameter for 305s
I have BFG right now...yea the tread is great but no traction...Whats the avg life span for Mickey Tires...The thing is I hardly drive it!...cuz I am in med school in NY and my car is in ATL...
Old Nov 26, 2008 | 04:59 PM
coachk's Avatar
coachk
A 10" wheel will work just fine with 305's. I have been thinking about putting these tires on as well, that way I don't have to change my wheels when I go to the track. I fit a 325 M/T on a 10" Weld wheel, but the tire rubbed on the inside shock area.325's are just too big. My Z looked great sitting there, but couldn't drive it without it rubbing. The only thing I don't like about driving on the street with DR"s is that at 100mph+ the back end gets a little loose. I can't tell you how long the M/T's will last because I don't DD my car.
BTW my offset is +43 on my SSR GT 3's 18x10
Old Nov 27, 2008 | 07:27 AM
scotts300's Avatar
scotts300
What about adding a baby spacer? Like 5 or 6mm? Mine are the SSR GT3 19x10.5 +43 with 305s, and I'd swear it'd take another half inch on each side or so. . . but maybe not! I use a 10mm spacer myself. . .
Old Nov 27, 2008 | 08:57 AM
thawk408's Avatar
thawk408
Iv got a 305/35/18 on the SSR GT2 +43 with 15mm spacer and I had to roll my fenders, but it clears perfectly fine now.
Old Nov 27, 2008 | 10:09 AM
coachk's Avatar
coachk
Scott-Thawk....are either of you guys lowered. I'm at stock height.
Old Nov 27, 2008 | 12:50 PM
scotts300's Avatar
scotts300
Nope - stock height; however, I have compressed the suspension and it doesn't appear that it would rub in the current condition. I could always remove the spacer, but I haven't had to thus far.
Old Nov 27, 2008 | 12:56 PM
coachk's Avatar
coachk
I have always worried about having spacers on the back and going down the track at 125mph. Someone educate me on why it would be OK
Old Nov 27, 2008 | 01:09 PM
original786
http://cgi.ebay.com/ebaymotors/2-305-35-18-MICKEY-THOMPSON-ET-STREET-DRAG-RADIAL-TIRES_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a 12Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZite m360102046510QQitemZ360102046510QQptZMotorsQ5fCarQ5fTruckQ5f PartsQ5fAccessories
These are tires I am thinking about ordering!...So...I should go ahead and get them right?!..and it should fit my rear rims which are 18x10..works XD9.
I want to thank you guys for your help!!!
Old Nov 27, 2008 | 01:20 PM
bighungrydewees
Sounds like you'll be fine.
Worst case scenario, you need like a 5mm spacer.
If I get another set one day, I'm buying M.T.
