spacer question
im running 19x8.5's +22 offsets and 9.5's +22 in the back... the stance of my car isnt aggresive enough for me so i was planning on getting some spacers and i was wondering if i could get 10mm spacers all around or if i should go with 5mm spacers all around. if it helps im running 245/35's and 285/35's.... thanks for your help in advance
+22s sit relatively flush so unless you got the rears rolled i wouldn't suggest anything bigger than a 15 out back and a 20 out front...this is just a guestamation you might wanna ask wheeldude
i've got a G35, so not sure if this will help, but I'm running same setup w/ 5zigens +25 all around. I got 20mm kics spacers front & back so now its +5. its pretty flush, slight rub in rear.
