Best way to mount Tire Pressure Sensor with ADR wheels?
I still haven't installed the ADR CH look a like wheels yet, primarily due to the difficulty having with how to mount the tire pressure sensors. How have the forum members been doing it? I saw the article on using a band and some small parts from Home Depot. However, it doesn't seem to prevent the sensor and band from moving around on the rim, which could lead to serious issues with balance.
What's the word on the TPS' guys and gals?
Mike linked the thread that you saw before. If you are still concerned about the strap rotating under heavy accelleration, buy some thin rubber sheets. Cut a strip the length of the band and place it between the band and the rim. The friction will keep the band from (a) rotating, or (b) scarring the rim. Please note that this has not been tested, so you are at your own risk.
liqalu04
Jan 2, 2022 12:58 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
