big probelm (help)
Old Aug 27, 2003 | 06:13 AM
havabooz's Avatar
havabooz
Default big probelm (help)
ok...so it happened last night when i was painting my calipers
i jacked up the left side of teh car (only have two jack stands)
when i finished one side of teh car (looks really good) i wanted to take the car off the jack stands
so i did...one at a time (i think i should have jacked the middle of teh car and taken off both at once
but heres what happend
the rear drivers side seemed a bit higher than the rear passenger side
and it was (by 1/2 inch)
so i got scared and didnt do teh other side of teh car
now i have to buy another g2 kit to paint teh other side (i dont really mind
but can anyone tell me why the car might be higher (is it cause the spring gets streched a bit when its raised?)
if i drive around a bit will my problem be solved?/
(in teh beginning it was an inch higher..then when i cheked this morning it was only half inch higher)
so i think the spring just needs to be worked in a bit...or maybe it will just be balanced out if i lift the passenger side of the car
should i be scared about this??
Old Aug 27, 2003 | 06:32 AM
j's350z's Avatar
j's350z
No problem at all... Anytime you jack up the car and take the weight off the suspension, it always "strectches" After you drive a couple of miles it will settle back to normal......
Old Aug 27, 2003 | 08:06 AM
havabooz's Avatar
havabooz
thank god....dammit...now i wasted perfectly good paint just cause im an idiot
anyway..thanks for clarifying that....my dad was ready to kill me
the words of my dad "everytime you add something on your brand new car somtething goes wrong dammit"
May 30, 2017 03:28 PM
Jambo016
Sep 16, 2016 01:08 PM
