17" 5Zigen Wheels
Hi guys, I have a 2004 Roadster Touring with the following wheels:
Standard factory 17"
Aluminum Alloy
Front
Offset: +30mm
Weight: 23.26lbs
Tire: 225/50/17 Toyo Proxies 4
Rear
Offset: +33mm
Weight: 24.14lbs
Tire: 235/50/17 Toyo Proxies 4
I want to install the following wheels using my existing Toyo's:
5Zigen ProracerGN+ 17"
Mat silver
Front
Offset:35/43/48 5H 114.3
Rear:
Offset:22/30/38/48 5H 114.3
Can I use 35 offset for front and 38 offset for the rear?
Will this wheel/tire combination look right with 17's all a round? I don't want to upgrade to 18's because the tires are brand new.
Aluminum Alloy
Front
Offset: +30mm
Weight: 23.26lbs
Rear
Offset: +33mm
Weight: 24.14lbs
Mat silver
Front
Rear:
I would not buy wheels to fit tires. 20,000 miles and you are stuck with wheels that are less than satisfactory.
