Could my tires be damaged?
Old Jan 14, 2009 | 11:25 AM
whitemikecn's Avatar
whitemikecn
Default Could my tires be damaged?
I was involved in an accident and in the process the car jumped 4 different curbs going between 30-40 miles per hour. I have spoken to several people who have said that even if the tires do not show damages they still could be on the inner layers. Basically I need some sort of article or proof to give the insurance company stating this fact so that I can get these replaced. I am super nervous to drive on these at 80 miles per after knowing what the have been through in the accident. Someone please help!!!
Old Jan 14, 2009 | 11:29 AM
terrasmak's Avatar
I wouldn't think tires would be the big concern.
Old Jan 14, 2009 | 11:32 AM
whitemikecn
The car is almost done... Any why wouldnt they be a big concern?
Old Jan 14, 2009 | 11:52 AM
terrasmak's Avatar
Oh ok , i guess there is a lot more damage that is boing fixed. Look at the tires, if they have no marks, bubbles etc etc they will be good.
Old Jan 14, 2009 | 12:06 PM
Not sure how you are going to get money for damaged tires unless they are damaged. Sorry.
Old Jan 14, 2009 | 01:11 PM
julian's Avatar
julian
pump the tires up to 40 psi or higher and check for bubbles. don't forget to look at the inside sidewalls.
Old Jan 14, 2009 | 02:13 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
If you hit multiple curbs at that speed, then yes it is a good possiblity that the tires received damage. The belts could be busted and the sidewalls could very likely be damaged. Take them to a reputable tire shop and have them unmount and inspect them carefully. To be very vague, you could have a range of nothing damaged to being completely toast. Unmounted inspection is the only way to know.
Old Jan 14, 2009 | 02:25 PM
Done Deal DR's Avatar
Done Deal DR
I love it!
Old Jan 14, 2009 | 03:46 PM
whitemikecn
I understand... Basically what I am wondering is if there is no visible damage would you be 100% confident that they are fine. It is a brand new set of tires and they cost me about 1200 a month ago...
Old Jan 14, 2009 | 03:56 PM
TreeFiddyZee
Do WHAAAAT!?
Originally Posted by Done Deal DR
I love it!
I"m like fertilizer. Brooaaad spectrum.
Old Jan 14, 2009 | 05:46 PM
Done Deal DR
Old Jan 14, 2009 | 07:20 PM
WhiskeyHotel's Avatar
WhiskeyHotel
Without visible signs of damage, this will be an up hill battle. If it bothers you that much, you may need to replace them yourself.
Old Jan 15, 2009 | 07:28 AM
HondaKiller's Avatar
HondaKiller
if they aren't leaking air and you have no bubbles from the impact, their fine. Inner damaged layer these nuts, that is a sale pitch. Unless you ran on it flat the inner wall containing wires is fine. Take care.
Old Jan 15, 2009 | 07:52 AM
j.arnaldo's Avatar
j.arnaldo
Just go to your nearest tire repair shop & have 'em tested in the water drum/tank, etc.
ablaine
Nov 29, 2016 10:13 AM
