18x10 +38mm okay with 305s?
Old Jan 14, 2009 | 05:25 PM
SnyperZ's Avatar
SnyperZ
Default 18x10 +38mm okay with 305s?
Like the title says, I really need to get as wide of a tire out back as possible..I really like the RPF1s and the size I found was 18x10 +38 offset in the back and 10x9.5 with a +15 in the front. I have a fender roller so I will roll them as much as I can without ruining the paint.. will it be possible to fit 305s out back?
Old Jan 14, 2009 | 05:27 PM
Nexx's Avatar
Nexx
that will definitely work unless your slammed ghetto style.
Old Jan 14, 2009 | 05:33 PM
Done Deal DR's Avatar
Done Deal DR
Most would call that rear offset "weak", but for your intended purpose of slapping 305's on there it makes sense to do that. However, you may be getting close to the inside fender well and suspension components as well with that offset so you have to be careful how much the 305's buldge out that would cause it to rub on the inside.
Old Jan 14, 2009 | 06:17 PM
eltness350's Avatar
eltness350
The Untouchable
it will work without any mods unless u r slammed like nexx said......i have very close to that offset with my wedsports and using m/t et streets!
Old Jan 14, 2009 | 06:19 PM
mikez97's Avatar
mikez97
jetpilot has 305 check his specs
Old Jan 14, 2009 | 07:10 PM
SnyperZ's Avatar
SnyperZ
how much do you think I can lower it and get away with? (again, with rolled fenders)
Old Jan 14, 2009 | 10:47 PM
JETPILOT's Avatar
JETPILOT
You can slam the car with those offsets with a rolled lip. I have 10" +35 with -2.0 camber in the rear and 305/35/18 tires. Go as low as you want. I am lowered 2".
Old Jan 15, 2009 | 06:52 AM
z-u-later's Avatar
z-u-later
You can actually go with an even wider tire in the rear with this setup:
- RPF1 18X10 +38 on all four corners
- Front: 295/30/18 w/ 15mm spacers
- Rear: 315/30/18 w/ 10mm spacers
https://my350z.com/forum/wheels-and-...r-rolling.html
Old Jan 15, 2009 | 08:12 AM
Done Deal DR
That is a great setup, I'd love to have something like that in the future!
Old Jan 15, 2009 | 08:15 AM
SnyperZ's Avatar
SnyperZ
That car is beautiful Jet. I found fronts that are 18x9 with a +35...
Old Jan 15, 2009 | 08:17 AM
mw9's Avatar
mw9
I agree, too bad he is selling it.
Old Jan 15, 2009 | 08:18 AM
iStan's Avatar
iStan
ZR
Jet's got more rubber than Trojan.
Old Jan 15, 2009 | 08:25 AM
SnyperZ's Avatar
SnyperZ
Well I think I just got a deal on a set of 18x10s +38 and 18x9s +35 if I end up getting them im going to do 305/35/18s on the back and 275/35/18s up front. I wonder how much different it will handle when compared to the 245/225 haha
Old Jan 15, 2009 | 08:41 AM
mw9's Avatar
mw9
NA or Fi, I would say thats alot of rubber for an NA car.
Old Jan 15, 2009 | 08:45 AM
SnyperZ's Avatar
SnyperZ
lol..I can tell you it wont be enough. LS2 with a 78mm turbo.
Old Jan 15, 2009 | 08:52 AM
Too small. Go 11.0 inches or not at all.
Old Jan 15, 2009 | 11:27 AM
JETPILOT's Avatar
JETPILOT
You will need a 5 or 10mm spacer on the front wheels. Other than that your ofsets and tire sizes are perfect. Are you going to run the Proxes R888?
Old Jan 15, 2009 | 06:06 PM
SnyperZ's Avatar
SnyperZ
Im gonna try the M/T street radials... Im gonna need alot of grip with the new setup..heres my track shoes..
Old Jan 16, 2009 | 08:59 AM
scotts300's Avatar
scotts300
No, there is plenty of room on the inside with that wheel width and offset. Probably near an inch, but I haven't measured.
[QUOTE=Done Deal DR;6809754]Most would call that rear offset "weak", but for your intended purpose of slapping 305's on there it makes sense to do that. QUOTE]
BTW, who is "most"? To run wide tires and wide wheels, out of the accepted norm of 275s or 285s, higher offsets are necessary.
Old Jan 16, 2009 | 09:48 AM
Done Deal DR
You're going to be getting close to the strut with that offset and those tire widths. I was just saying be mindful of this.
Most would be the "Aggressive wheels and stretched tire" folks that practically dominate this site if you haven't noticed. That's why I said it makes sense for the intended purpose.
