TPMS not showing pressure readings..
Old Jan 17, 2009 | 03:59 PM
s2drummer988's Avatar
s2drummer988
Default TPMS not showing pressure readings..
I just bought a 2003 enthusiast 350z and it is not showing tire pressure readings . Just dashes across where the numbers should be. However, the (!) tire pressure light does work, as I found out the other day when it came on, I aired up and it went off.
Also, I am planning on buying these wheels in the near future.
http://www.wheelsnext.com/wheels-rim...k%20gloss.html
Will it be difficult to get someone to mount the TPMS sensors on them, I know that some wheels make it difficult depending on valve stem placement.
Thanks for any help, and I look forward to being part of my350z.com!
Old Jan 17, 2009 | 04:01 PM
surfcity40's Avatar
surfcity40
The sensors aren't in the wheels apparently. Yes, if you wish to use the sensors the wheels have to have a 90 degree outlet for that inflation thingie.
Old Jan 17, 2009 | 05:37 PM
DavesZ#3's Avatar
DavesZ#3
https://my350z.com/forum/showthread....9&postcount=44
Read that post and some things may make more sense.
I'm guessing you don't have any sensors in your current wheels. You're probably going to have to buy 4 and get them programmed to your car.
Old Jan 17, 2009 | 06:59 PM
terrasmak's Avatar
Please don't bother with those wheels. 8.5 front 9.5 rear minimum when you looking at wheels. Offsets +25 or lower.
apex locator
Jul 23, 2021 02:27 AM
