Wheel spacers for R20 or not..?
Old Jan 24, 2009 | 05:00 AM
Pathfinder's Avatar
Pathfinder
Default Wheel spacers for R20 or not..?
Just has bought new R20 wheels.
(same front and rear)
Rial Porto (made in Germany)
- 20 x 9.0
- 5 x 114,3
- Hub 70.1 mm (They gave me plastic "hub centering rings (looks like plastic ****)" huh)
- Offset 38
Front tires should be 235/30/R20 (not sure about 245/30/R20...?) and rear 275/30/R20 (not sure about 285/30/R20??)...
So, i need "wheel spacers"? Or everything should be ok without it?
p.s. its ok if hub centering rings are PLASTIC??
p.s.2. 04 350Z Track (with Brembo) ... Wheels do not touch brembo.
As i see using http://www.rims-n-tires.com/rt_specs.jsp wheel/tire calculator, BackSpace will be 165mm ... (with stock 350Z Track 18/19" v.2 wheels and tires BackSpace is 157mm)
Old Jan 24, 2009 | 06:19 AM
sry110's Avatar
sry110
Plastic hub rings are fine in my opinion. I use them with no issues.
+38 is pretty high offset. Most people would be looking for an offset in the mid 20's or lower. I think maybe a 12mm or 15 mm spacer would make the rear wheels look good.
Old Jan 24, 2009 | 06:23 AM
calin's Avatar
calin
I think it's better to do research like this BEFORE buying wheels instead of after. You could have gotten some much better widths and offsets.
Old Jan 24, 2009 | 08:00 AM
Pathfinder's Avatar
Pathfinder
Not in my location...
Only few 19 and 20 wheels with 114.3 here ... I has bought this wheels after 2 months of searching.
Old Jan 29, 2009 | 11:30 AM
Pathfinder's Avatar
Pathfinder
Well. It will be ok if I will use for first time 5mm spacers for each wheel?
So offset will be 38 - 5 = 33mm @ 20" x 9.0 front and rear...
Everything should be ok (i talking about functional part) with wheels/car?
Old Jan 30, 2009 | 01:05 PM
shake_urzada's Avatar
shake_urzada
in my opinion you should get 20-30 mm for rear and 5 should be alright for front.
Old Jan 30, 2009 | 01:15 PM
Done Deal DR's Avatar
Done Deal DR
Step One: Mount Wheels front and rear (one side only)
Step Two: Pull out ruler and measure # of MM you would like the wheel to come outwards towards the fender.
Step Three: Buy that size spacer or closest you can find to that size spacer without going over.
Old Jan 30, 2009 | 01:16 PM
Done Deal DR
This will be my first time ever seeing a square 20" setup on a Z, 9" wheels at that, this should be interesting.
Edit: why are you thinking of getting different size tires on the same size wheel? That's kind of silly IMO with wheels of the same width. Get the same size all around. Just do it.
Old Jan 30, 2009 | 02:52 PM
zSupreme7's Avatar
zSupreme7
20x9 +38 all around? TERRIBLE choice. Is it too late to return?
Go with 30mm spacer rear and 25mm spacer front.
Old Jan 31, 2009 | 02:15 AM
Pathfinder's Avatar
Pathfinder
Well, there was discount 60% (perfect price!)... And as I have already told, it is very hard to find 20 "114.3 in my area.
Hmmm, if i will go with 25mm both or 30mm and 25mm... I will be able to use my stock wheels (18"x8 +30 and 18"x8.5 +33 ... it's Track v.1) to (with spacers)? Using stock wheels for winter...
Any-way, thanks for advice
Obadabot
Jun 18, 2023 11:31 PM
