Help!! wheel spacer suggestion
Old Jan 27, 2009 | 01:54 PM
oneqkz's Avatar
oneqkz
i just wanna make it look even all around to make it look alittle flush...
Old Jan 27, 2009 | 02:00 PM
kelsey_kaye's Avatar
kelsey_kaye
go get a ruler and measure how much room you still have until it's flush.. bam. there's your answer.
Old Jan 27, 2009 | 03:20 PM
oneqkz's Avatar
oneqkz
15mm front and 10mm rear just to even things out ..
Old Jan 29, 2009 | 06:54 AM
oneqkz's Avatar
oneqkz
ttt
Old Jan 29, 2009 | 07:48 AM
redlude97's Avatar
redlude97
Originally Posted by scotts300
If his set-up really is 19x8 +25 & 19x9.5 +25 with 245/35/19 fronts & 275/35/19 rears, he has little room for a spacer - especially in the rear. Maybe 10-15mm front and 10mm rear, no way a 30 front and 25 rear though. That would put the front at 19x8 -5 and the rear at 19x9.5 +0, and without superstretchedsilly tires, that just won't work.
Why wouldn't it? I've run 9.5+5 with a 285/35/19 -1.6 camber with 5mm of clearance still
Old Jan 29, 2009 | 10:10 PM
scotts300's Avatar
scotts300
That surprising. Do you have a picture of the set-up? Was the car lowered or any fender modification? I put a 15mm spacer on my 19x9.5 +22, netting it a +7 and it rubbed badly. That's why I said, "no way" to a huge spacer for the rear wheels.
Old Jan 30, 2009 | 10:48 PM
oneqkz's Avatar
oneqkz
ttt
Old Jan 30, 2009 | 10:55 PM
redlude97's Avatar
redlude97
Old Jan 31, 2009 | 08:01 PM
oneqkz's Avatar
oneqkz
are u running a spacer ??
Old Feb 3, 2009 | 05:15 PM
scotts300's Avatar
scotts300
Lowered at all? Rolled fenders? It looks like it'd rub at full compression without a roll.
