wheel spacer question
Old Jan 27, 2009 | 07:14 PM
ma6icman's Avatar
ma6icman
Default wheel spacer question
I tried seraching but couldnt find anything, Im looking for a diy on installing wheel spacers with built in stubs?
Old Jan 27, 2009 | 07:19 PM
bizcotch's Avatar
bizcotch
Ever heard of GOOGLE?
Google Advanced Search
Preferences
Web Results 1 - 10 of about 71,200 for diy wheel spacer install. (0.19 seconds)
Search ResultsHow to install wheel spacers | Wonder How ToHow to install wheel spacers A wider wheelbase will improve handling and make your vehicle .... Save gas 1:49 (B+) 1 · How to dIY a redneck roller-coaster ...
http://www.wonderhowto.com/how-to/vi...pacers-166350/ - 65k - Cached - Similar pages
diy (dim) wheel spacers- 8 pics - forums.GenerationDub.com30 posts - Last post: May 7, 2004
diy (dim) wheel spacers- 8 pics Exterior. ... I could counterbore the wheel bolt holes and put flathead allens in there, then install studs ...
forums.generationdub.com/showthread.php?t=6116 - 166k - Cached - Similar pages
Scion tC Ichiba USA Wheel Spacer Install DIYIchiba USA wheel spacer install DIY So Micah and I finally got around to installing my Ichiba wheel spacers today. 15mm front and 20mm rear. ...
http://www.diycarmods.com/articles/5...DIY/Page1.html - 33k - Cached - Similar pages
Wheel Spacer Install - InfinitiScene.comDIY Wheel Spacer Install .... After all said and done when your wheel is back on , in the front,does the stud fill in the lug all the way, ...
www.infinitiscene.com/forum/showthread.php?t=91 - 88k - Cached - Similar pages
Old Jan 27, 2009 | 08:54 PM
ma6icman's Avatar
ma6icman
Thanks but I'm looking for a diy on installing spacers that have built in studs.
Old Jan 28, 2009 | 07:26 AM
reverse's Avatar
reverse
real easy....just look at the visual instructions (assuming you got kics). just align the studs on your wheel hub w/ the holes on the spacers & bolting them down w/ the spacer's lug nuts (don't forget to put hub rings on). then just put your wheels back on using built in spacer studs. drive around the block, take the wheels off & re-torque the spacers. your done.
Old Jan 28, 2009 | 07:34 AM
militia's Avatar
militia
<A HREF="http://smiliesftw.com"><IMG SRC="http://smiliesftw.com/x/greenface2_7.png" border="0" ALT="SmiliesFTW.com"></A>
Old Jan 28, 2009 | 07:55 AM
dennisafrompa's Avatar
dennisafrompa
Ichibas have the studs built in on 15 and 20mm sizes.I have them on my 350 and they are road and autocross tested.
Old Jan 28, 2009 | 08:19 AM
Entaille's Avatar
Entaille
depending on the wheel you may run into complications. I have 19" TSW Mondello's and they would hit the back of the stock stud rather then sitting flush against the wheel spacer. ended up having a local shave them down for me.
its really simple though as others have stated. pull your wheels off, nut the spacers to the wheel hub, nut the wheel to the wheel spacer, drive it for some time, take the wheel off and re-torque the spacers (I waited a few days), put the wheels back on and you're good to go. torque the spacers close to what you would torque your wheels to.
Old Jan 28, 2009 | 07:18 PM
DustinZ33's Avatar
DustinZ33
Mount the spacer to your car just like the wheel is mounted. Then mount your wheel to your spacer just like normal. Some wheels don't work because they don't have a space for the stud to fit.
_koubie_
Sep 20, 2015 06:34 PM
torchkc
Sep 11, 2015 08:26 PM
