Question wheel whiz guys
Old Feb 1, 2009 | 07:22 PM
WV350z's Avatar
WV350z
Default Question wheel whiz guys
I am interested in some wheels on the forum for sale.They are 18x9.5 all 4..and they are +12mm offset...Would this offset and set up look right on a Z.Never really seen such a offset combo on a Z..how aggressive would it be?How much room for suspenion work also?
Old Feb 1, 2009 | 07:47 PM
zhuangzi's Avatar
zhuangzi
i have the same size with +15 on a g35 coupe and the fit is fine with coilover... more than enough space
Old Feb 1, 2009 | 07:54 PM
Kwame's Avatar
Kwame
I'll put money on these being the wheels you were looking at purchasing (except in "green")...
https://my350z.com/forum/6309251-post163.html
Old Feb 1, 2009 | 08:03 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Feb 1, 2009 | 08:18 PM
WV350z's Avatar
WV350z
nope those arent the wheels...theres a set of T57-RCs a seller has on here for sale.I'd rather stay away from spacers on the rear.Only if they were 10.5...and david thanks for the site!
Old Feb 1, 2009 | 08:22 PM
zSupreme7's Avatar
zSupreme7
Those will fit and look fine. Might want to run spacers in the rear to even up the look, though.
Old Feb 1, 2009 | 08:30 PM
WV350z's Avatar
WV350z
what size spacers would you recommend?
_koubie_
Sep 20, 2015 06:34 PM
sherm
Sep 10, 2015 11:02 PM
