Tires
Feb 3, 2009 | 05:02 PM
Tires
Which size of tires should I run with my 19" 9.5 and 19" 10.5 rims offset+22.I'm hesitate between 245 or 255 in front and 275 or 285 on rear.Thanks
Feb 3, 2009 | 05:06 PM
i would personally go 255 front and 285 rear.
Feb 3, 2009 | 05:32 PM
If I run 255 front and 285 rear do I need to roll fender?Thanks
Feb 3, 2009 | 05:43 PM
lawdy lord you read my mind. I was just thinking about this question earlier, but wasnt sure if I should ask it or not. Dude me and Panu need more insight. please help.
Feb 3, 2009 | 05:50 PM
How much power are you putting down? Do you auto cross? or straight line stuff?
If you aren't putting much power down I'd get 275 in the rear.. 285 is more drag for no reason..
If you auto cross I'd put 255 in the front, straight line racing/ every day driving 245 (cheaper, less drag)
Feb 3, 2009 | 06:05 PM
Quote:
Originally Posted by
Panu
i doubt you will unless your lowered quite a bit.
Feb 4, 2009 | 01:55 AM
Super Moderator MY350Z.COM
275/30 front, and the 285 or 275/35 rear . I wouldnt run less than the 255 front if you decide to go the skinny route
Feb 4, 2009 | 03:39 PM
I think the recommended size is 245/275
Feb 4, 2009 | 04:31 PM
255/275 has been my fav so far. i would like to go 275/275 though
Feb 4, 2009 | 11:19 PM
Get_Zwole
Thats my next setup, unless i decide to run a 275 295 setup. Either was i would never want to run anything more than the facory 20mm stagger, less stagger would even be better.
ablaine
Nov 29, 2016 10:13 AM
