Will these fit my Z???
So I am a total noob when it comes to rims. I am getting my car hopfully in the extreme near future and I have money already saved up for rims, however, I have no idea what rims will fit a 2008 350Z Enthusiast (the car I am getting). I've provided a link to the rims I ultimatley would like, however, if you guys out there could take a look at them and let me know if they'll fit my Z I'd greatly appreciate it.
Thanks.
Here's the link:
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Thanks.
Here's the link:
Sorry about all the noob questions. I've just never really educated myself when it comes to rims.
Thanks
if you are getting some crazy good deal on these wheels then i would tell you to buy them. but.......i would look around for a different set of wheels if you are interested in a perfect looking fitment
K, ummm.... another noob question here: What is "offset"??? Also, these rims only come in an 8.5 up front, being as you said I'll want a 9.5 up front, what problems could arise with an 8.5 in the front??? What are spacers???
Thanks
Thanks
Going back to my original comment in this thread where I provided a link to the rims I liked, will those rims rub against any part/s of my Z as described in the link in my quote???
Thanks man, that helped!!! I was reading in that document that if you have the wrong size rim they might rub against suspension and other parts of your car (which obviously isn't good).
Tucked as in it will looked as if the rim were pushed/tucked into the tire???
Damn, is finding rims for cars always this complex or is it only a problem with the 350z??? Seems like everything with the Z in regards to aftermarket is a hassel. Times like these make me consider buying a STI...but then again, the Z is extremely clean...subaru is not!
So then can any of you guys who have been through this process before recommend any brands/websites that offer 19 inch 6 spoke rims that will offer a perfect fitment for the 350Z. If you know of any please let me know.
Thanks again everyone
Naw its just that the Z can litterally fit hundreds of different offsets/sizes. It can be overwhelming but take these guys advice look around and look for a set with a +22 to a +15. what he means by tucked is that your wheels will look sucked into the fenders. Anything more than around a +25 offset in those sizes is gonna look really unagressive. Umm me personally I would look in the classified section of this forum and try to find a used set of wheels that will fit right. Most of the people are really accomadating especially if they are selling something and will send you pics of the wheels on the car. Oh and offset in lamen terms....the closer to zero the further out from your hub the wheels will sit. and this is probably the longest post ive posted so feel special
I might be going against the grain here, but as I just did a crapton of research to get new shoes too, these are the conclusions I came to:
+28 to +32 offsets are perfectly fine. They are closer to factory specs than the popular +22 (factory is 30 or 33), deal very well with the oem suspensions' geometry, and don't really look that different from +22 on wheels 9.5 and up.
Not identical, but not so radically different. +22 won't mess with the geometry that much, but it's still close to running small spacers.
On 8.5 with +33 yes, it will look a bit tucked in, basically the same of the factory front 8", how significant that might be is up to you. It definitely isn't the wrong size for a 245 though.
8.5 will fit most 245 ideally, it might tend a little bit toward the pinch, rather than the stretch, but only on very few tires.
Far from me saying that people saying you need 9" for 245 or that the wheels will look tucked in with those offsets are wrong. Just saying that you might want to look into things yourself and understand what the numbers mean first. Somebody's idea of aggressive is somebody else's rice, and somebody's idea of technically ideal is somebody's boring look.
I ended up with 9 front and 10 back for 245 and 275 only for availability/shipping times, still very happy with it, but seeing how things sit I definitely would have liked 8.5 and 9.5 just as much, if not more, and I run factory like offsets.
And if you feel like educating yourself, this is a good starting point:
http://www.*********.com/zwiki/Wheels_and_Tires
It really isn't that complicated if you do some research and aren't pathologically impatient
Browse this forum - there are tons of pictures and tons of wheel specs to go along with them. You will find a spec that you like and you'll learn a lot.
also: http://www.1010tires.com/WheelOffsetCalculator.asp
is your friend.
is your friend.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
