Widest Tire on Stock Rims
Old Feb 14, 2009 | 04:33 PM
rtiid22's Avatar
rtiid22
Default Widest Tire on Stock Rims
I own an 08 with factory wheels, specs as follows: 18"x8.0" front & 18"x8.5" rear. What's the widest tires I could put on these rims and be safe?
Factory sizes are 225 up front and 245 on rear..
Old Feb 14, 2009 | 04:37 PM
Spork's Avatar
Spork
Why do you want to do that?
Old Feb 14, 2009 | 05:15 PM
rtiid22's Avatar
rtiid22
Better Traction............ ... ....... . .
I wheel spin throughout first gear..
Old Feb 14, 2009 | 05:28 PM
Phantom Menace's Avatar
Phantom Menace
...just don't mash on the gas getting out of 1st...
mikez97's Avatar
mikez97
Old Feb 14, 2009 | 05:55 PM
vnarang's Avatar
vnarang
Originally Posted by mikez97
275
finally a straight answer
Old Feb 14, 2009 | 05:56 PM
WhiskeyHotel's Avatar
WhiskeyHotel
275 is pretty wide for the rear. You might want to drop back one to 265. I'd go about 245 on the front.
06g35meister's Avatar
06g35meister
275, did it myself
Old Feb 14, 2009 | 07:01 PM
terrasmak's Avatar
Not really a straight answer, its actually a stupid answer. A 275 does not work well on a 8.5 inch wheel. Hell i ran 275's on 9's and the mid corner squirm sucks, and will be worse on an 8.5. Minimun width is 9.0 for a 275, and when you drive on one with that rim , you will know it sucks.
The widest is a 265, and that won't be very hot either. Buy wider wheels or just buy some sticky tires in the stock size.
Old Feb 14, 2009 | 07:30 PM
Pick a number. Any number. Someone will tell you that it can be done. Try it.
Old Feb 14, 2009 | 10:12 PM
rtiid22's Avatar
rtiid22
Thanks guys, just curious to see if putting 265 in the rear would be kinda reckless if I'm taking quick corners hopefully the tire doesn't fly off the rim! Can't really afford the rims I want at this time so best next thing is wider sticker tire once it's time, I can't justify buying affordable rims for the mean time and reselling them later down the line..
Old Feb 15, 2009 | 07:17 AM
ThE_JacO's Avatar
ThE_JacO
8.5 is max 265, and you're already pushing it.
275 on 8.5 can be done for the sake of doing it, but I seriously doubt it's going to get you better traction than a well seated 255, more likely it'll be worse, not to mention slightly dangerous.
More 8.5 wheels than not (and I looked into more than I can care counting) are rated 265 max, not 265 ideal, let alone 275.
Stick to stock tyre sizes or up 10 and get better tyres if you want grip without changing wheels.
Flooring in 1st, for the record, still spins on 275 on 10" with brand new fk452 and 80% thread Yoko Advan (only shoes I tried on for now).
Old Feb 15, 2009 | 01:13 PM
maximariceboi's Avatar
maximariceboi
i would put more than 255 for the rear but...from looking at your thread..its been done with 265! but this might make your tires bulge out too much???
Old Feb 15, 2009 | 01:22 PM
kham25's Avatar
kham25
IF you have to do the rears 275/40/18.. I've seen another Z owner who had 275/45/18 in the rear jesus christ the car looked like a 4 by 4 truck hideous ..
If i was you i was save up and buy wider wheels do it right!!!
Old Feb 15, 2009 | 07:19 PM
350zDex's Avatar
350zDex
Ive put a 27540 on my stock 8" rims and they worked perfectly fine!!
Old Feb 15, 2009 | 07:31 PM
Spork's Avatar
Spork
Wider tires on skinny wheels? Keep in mind, sidewall flex is an issue that hinders cornering and handling performance.
Old Feb 15, 2009 | 07:41 PM
SirSpeedyZ's Avatar
SirSpeedyZ
Good ol' davidv
Old Feb 15, 2009 | 09:10 PM
scotts300's Avatar
scotts300
Originally Posted by 06g35meister
275, did it myself
^^^^ which doesn't make it right, safe, or within the tire manufacturers recommended sizes.
Old Feb 16, 2009 | 02:55 AM
ThE_JacO's Avatar
ThE_JacO
Do you have a pic to show for it?
I'm sincerely curious, mine came with 235 on stock 8J and I already thought it a bit pinchy. I honestly can't imagine adding another 2cm per side without it looking like somebody wrapped a kids' inflatable pool around the wheel.
I'd question the handling and feedback of that too.
Old Feb 17, 2009 | 11:50 PM
stunter4hire's Avatar
stunter4hire
does anyone run 40mm instead of 45mm on all four tires with stock wheels?
