TPMS
I have an 07 Z. I removed the sensors to install on GT-S wheels. Each sensor has a number on it ie 1,2,3,4,. Is this to show which sensor goes where? If so, does 1=left front, 2=right front etc...? Any info greatly appreciated guys. Thanks.
i think since its an 07 model, it does not show individual tire readings...
if any of the four have low pressure, the dash low tire pressure light comes on.
Because of this, it doesn't matter which goes on which
Question to the OP, did you remove the sensors from the stems? Could I remove the sensors from the stem valve and reuse the valve or are they both integrated together? Thanks.
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
