Need advice
Old Mar 8, 2009 | 03:56 PM
ni-z-mo's Avatar
ni-z-mo
Default Need advice
Im planning on making my car look alittle more aggressive while still using the factory 07 rim for now, so I was thinking of 2 option.
1. I was gonna upgrade to wider tires, 245/40 front 265/40 rear.
2. Or go with 25mm spacers all around.
So my question is which would be the most safe and reliable option? Also how long do spacers last?
Thanks
Old Mar 8, 2009 | 04:39 PM
vthao's Avatar
vthao
Get the spacers. This will flush your rims to your fenders. Unless you do hardcore auto crossing, these things will last forever.
Old Mar 8, 2009 | 04:42 PM
mikedbz's Avatar
mikedbz
I wouldn't advise running too wide of a tire for your wheel.
The 25mm spacers I think will require you to install longer wheel studs, but should work out fine after you get extended studs.
Old Mar 8, 2009 | 05:18 PM
terrasmak's Avatar
20mm front with a 245/40 and stock rear tire with 25mm spacer would be my suggestion.
Old Mar 8, 2009 | 10:10 PM
ni-z-mo's Avatar
ni-z-mo
Default spacers
Why do I need extended studs? I was planning on getting the ichiba version II spacers. The studs that come with those spacers should be long enough right? So I guess spacers are more reliable than wider tires?
thanks
Old Mar 9, 2009 | 05:20 AM
If you want wider tires I recommend wider wheels.
Old Mar 9, 2009 | 07:17 AM
Z04's Avatar
Z04
you forgot option 3. save up your money and do it right the first time.
norrix420
350Z Roadster
May 23, 2022 05:11 PM
liqalu04
Jan 2, 2022 12:58 PM
user 62082028
Southern California
Jul 28, 2017 11:47 AM
BumbleZee
OZOC (Orlando Z Owners Club)
Sep 26, 2015 01:00 AM
