tire size question for 17's
Old Mar 11, 2009 | 11:35 AM
reserved's Avatar
reserved
Default tire size question for 17's
Considering running RPF1's 17x9 and 17x10 as a track set-up.
Would 255/40/17 F and 275/40/17 R work OK????
(meaning from a VDC/ABS standpoint, because of the slightly smaller diameters than stocK)
TIA
Old Mar 11, 2009 | 01:36 PM
scotts300's Avatar
scotts300
If it's a track set-up, VDC can be turned off. Regardless, those sizes should be fine, although I love my 275 all-around set on 17x9.5 RPF1s. You could still run 275s on your 9/10 combo.
Old Mar 11, 2009 | 04:06 PM
reserved's Avatar
reserved
Thanks Scott - always appreciate your expertise with this stuff
I assume you are running 275/40/17 also?
Old Mar 11, 2009 | 04:39 PM
Spike100's Avatar
Spike100
I cannot say for sure since I’ve never personally run these sizes on a VDC-equipped car, but I would say you are OK with the sizing you ask about (255/40/17 F and 275/40/17 R).
  • Your fronts have an overall diameter of 25.03 (3.18% less than stock), and thus not within OEM specification.
  • Your rears have an overall diameter of 25.66 (2.25% less than stock), which is within OEM specifications.
The significant comparison here is that your fronts are not taller than your rears (“shorter rears than fronts” is always a problem with VDC).
The ideal sizing (overall diameter) for the widths you ask about is: 255/45/17 F and 275/45/17 R). Of course these sizes may not be available in the tire brand you are considering.
I really think you’re good to go with the sizes you ask about.
--Spike
Old Mar 11, 2009 | 04:49 PM
reserved's Avatar
reserved
Yes, you are absolutely correct - 255/45/17 and 275/45/17 would be ideal, but they are "orphan" sizes and not available in any R-comp tires that I can find.
Again though, I appreciate the reassurance that 255/40/17 and 275/40/17 will work without any issues.
Thanks for the input
Old Mar 11, 2009 | 08:20 PM
Difference in front-rear tire circumference is 2.5 percent. VDC will be happy.
Old Mar 12, 2009 | 03:41 AM
reserved's Avatar
reserved
Thanks David
Old Mar 12, 2009 | 10:02 AM
scotts300's Avatar
scotts300
Yes sir! 275/40/17 Hoosiers on 5Zigens for track and 275/40/17 V710s on RPF1s for autox. I used to run 255/40/17 and 275/40/17 on an old set of RP02s as well as the 5Zigens the Z came with without issue.
275/40 Hoosiers all 4 on 5Zigens:
255/275 RA1s on 5Zigens (for sale):
275/40 V710s all 4 on RPF1 to come this weekend.
Cheers.
Old Dec 6, 2009 | 11:56 AM
bbs350z's Avatar
bbs350z
i just piced up a set of enkei rpf's in 17x9.5 square setup. running 245/45/17 on all 4. on a vdc equipped car (track car only). this wont give me any issues will it?
also tires were dunlop direzza star spec. how do these tires fair?
Old Dec 6, 2009 | 12:35 PM
steven350's Avatar
steven350
i got kdw`s on my 17 oems.. front i got 235/40/17 rear 255/40/17 i love those tires so much but when i mounting them i saw the gap on my car.. way too much for me.. i tried to lower it as much as i could ( driveway safety ) not to pleased.. i need more sidewall or bigger wheels...
Old Dec 6, 2009 | 04:34 PM
terrasmak's Avatar
^^^^ yup you need wider wheels , then you can run the 255/40 275/40 combo, but really thats still to short for street driving(great fro track) Just get bigger and wider wheels.
Old Dec 7, 2009 | 12:27 AM
solidsnake's Avatar
solidsnake
255/40/17 275/40/17
Old Dec 7, 2009 | 07:20 PM
steven350's Avatar
steven350
^ your sidewall looks so much bigger..... you sure those are 40's? what kind of springs you got?
Old Dec 7, 2009 | 11:14 PM
solidsnake's Avatar
solidsnake
40s. Hotchkis springs
Old Dec 8, 2009 | 02:28 PM
scotts300's Avatar
scotts300
The total sidewall on a 275/40 is 8.66", or 4.3" for the top and 4.3" for the bottom. A 275/45 would have an enormous 9.75" total sidewall, or ~4.9" all around.
Old Dec 8, 2009 | 11:07 PM
solidsnake's Avatar
solidsnake
^also realize I am black on black so it is more of an illusion I highly recommend this setup, response it flawless on the car, it feels light and responsive. I am no track junkie but if I was to take it to the track I am sure this setup would work well.
Old Jan 13, 2010 | 01:48 PM
ZRated67's Avatar
ZRated67
I tried running 245/45/17's on all four corners, and while tracking the car, the ABS cut out. I flat spotted two brand new tires, and learned a valuable lesson. It may be fine for the street, but unless those rear tires are larger than the fronts, you're going to have problems. Running 225/45/17's up front will eliminate this problem.
To answer your secondary question, the Dunlop Direzza Star Specs are AWESOME. Dry or wet, they are amazing.
footballmania32
Wheels Tires
Oct 20, 2015 09:08 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
