Spacer size advice
Old Mar 12, 2009 | 09:51 AM
meanthedope's Avatar
meanthedope
Default Spacer size advice
Ive been searching around the board but couldnt find the right answer for my offsets I should get for my setup. currently i am running volk gtc 20x9.5 +22f on 245s 20x10.5 +22r on 275s and lowered on tein stechs with the spring mount cut and my fenders are rolled. What size spacers for the front and rear would make my setup most aggressive or flush? I was thinking about going 15mm in the rear and 10mm in the front or should I go 5mm front and 10mm rear? but was wondering about clearance? Also what brand would you suggest? Please advise.
TIA.
Old Mar 12, 2009 | 09:53 AM
jduet's Avatar
jduet
Take a ruler and measure how far out you want them to be.
I'd recomend project kics by the way.
Old Mar 12, 2009 | 09:59 AM
meanthedope
i did. i measured 15mm for the rear but it pushes the top of the tire out flush with the fender. should I run negative camber so it tucks in for clearance or should i just run 10mm?
Old Mar 12, 2009 | 10:59 AM
Chad350z's Avatar
Chad350z
run the 15 (if thats what you measured) and with the proper camber adjustments should make it nice and flush. 10 up front will be fine also. If you dont have a camber kit i suggest a SPC rear camber/toe kit $159.00, and for spacers defenently recommend PROJECT KICS!
Old Mar 12, 2009 | 11:09 AM
meanthedope
yes i was planning on project kiks for the front in 10mm and ichiba v2 for the rear since its hubcentric.
Old Mar 12, 2009 | 02:07 PM
Chad350z's Avatar
Chad350z
project kics sells hub centric rings for 30 bucks, plus your rims should have came with some?
sales@czp
Sep 23, 2019 03:30 PM
