volk gts + spacers??
Old Mar 15, 2009 | 03:47 PM
chad_z33's Avatar
chad_z33
Default volk gts + spacers??
i have volk gts's 19x9.5 +17 19x10.5 +18.how thick of a spacer will i be able to run?my fenders are rolled flat.got camber kits too.thanks in advance..pics if available.
Old Mar 15, 2009 | 03:57 PM
JermyZ's Avatar
JermyZ
good lord thats not wide enough for you already?!
Old Mar 15, 2009 | 04:10 PM
cheshirecat79's Avatar
cheshirecat79
Those are basically flush with the car unless you're running some widebody kit. If you run a spacer, you will need to go with some negative camber to avoid pulling the fender.
I don't really understand what you are trying to accomplish.
Old Mar 15, 2009 | 04:15 PM
GooDy151's Avatar
GooDy151
Those are flush set up with 285 tires in rear.
Old Mar 15, 2009 | 04:18 PM
chad_z33's Avatar
chad_z33
i want a really aggressive look.i want to keep the stretch tire look.im running 265 rear tires.
Old Mar 15, 2009 | 04:37 PM
cheshirecat79
Have you actually put the wheels on the car and seen how aggressive they are?
Old Mar 15, 2009 | 05:14 PM
BarefootRacer's Avatar
BarefootRacer
If you have 265 rear tires you will be able to run 15mm spacers and about -2.0 camber without a problem.
Old Mar 15, 2009 | 09:29 PM
chad_z33's Avatar
chad_z33
what about 25mm spacer with 275 rear tires?
Old Mar 16, 2009 | 01:16 AM
Ed Hardy's Avatar
Ed Hardy
10mm would be great. Any bigger than that and you'll have to run really stretched tires or crazy camber.
Old Mar 18, 2009 | 12:22 AM
saberphx's Avatar
saberphx
if anyone is interested im about to put some spacers on my gts', got some camber so they aren't flush, going to have them poke out just a little..
Old Mar 19, 2009 | 02:01 PM
chad_z33's Avatar
chad_z33
15mm with 275 rear tires 245 front tires?
Old Mar 19, 2009 | 03:22 PM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
post pics please
Stevo Z
Oct 3, 2015 09:14 PM
