19x9.5" & 19x10.5" ET22 Tyre Sizes
Old Mar 23, 2009 | 01:27 AM
Colin_S's Avatar
Colin_S
Default 19x9.5" & 19x10.5" ET22 Tyre Sizes
I know this has been discussed a million times but it is hidden in threads all over the place and not easy to search for so as this is probably the most common after market wheel size for the Z i thought it might be a good idea to put all the discussions about tyre size for these wheels in one thread titled appropriately.
So what tyre brand are you running, size are you using, what look does it give, what camber you running, did you roll your fenders, is it lowered and if so how and how far and do you have any rubbing?
I'll start:
PS2 245/35-19 front & 275/35-19 Rear
Slightly stretched look
I have -1.32 Camber on the front and -1.37 on the rear
Standard Fenders
Dropped on Tein Flex as low as the rear can go and cut upper rubbers, the front down to balance out the rear
No Rubbing
Old Mar 23, 2009 | 06:33 AM
zman600's Avatar
zman600
Great Idea!
but is 19x8.5 19x10.5 alright? it the second most common.(better for turn in responce)
anyways i have michelin pilots
255/35/19
295/30/19
tires line up with lip. no stretch.its a preference i like.
camber -stock suspension setup (coilovers coming i'll update it when they come)
no rolling. no rubbing(but i am -225lb now so i might be a little higher then most)
looks like i need a drop tho. dont worry im trying hard to get the coilover asap
Old Mar 23, 2009 | 11:44 AM
nd2spd's Avatar
nd2spd
19x9.5 & 19x10.5 + 22 F&R
255/35/19 NITTO INVO
285/35/19 NITTO INVO
Tein S-Tech 0.7"F / 0.6"R
Rolled Fender
Old Mar 23, 2009 | 11:51 AM
RIMTUCK's Avatar
RIMTUCK
___
sales@czp
Sep 23, 2019 03:30 PM
