rear wheel studs?
Old Mar 29, 2009 | 04:38 PM
blktrack350's Avatar
blktrack350
Default rear wheel studs?
How do you replace the rear wheel studs without pulling them threw by just tightening it down. I would like to tap it in from the back of the stud like I did on the front to prevent it from cross threading by pulling it threw. i really need some help i need my car for work and figured the weekend would be long enough but i ran into problems. i was told to remove the wheel hub and i cant figure out how to get it off. i have the axle nut off but i cant get to the back bolts.
Old Mar 29, 2009 | 04:42 PM
terrasmak's Avatar
Pain in the Azz , just pull them thru using a stud installer or an open ender lug nut and 5 or 6 flat washers to act as a bearing .
