Help....Can a +40 offset work???
Old Sep 14, 2003 | 06:01 PM
G-Ryder's Avatar
G-Ryder
Question Help....Can a +40 offset work???
I did a search already with no results. I have a chance to get some 18x7.5 LE37 for a good price. But would the offset of 40 work all the way around? Please help me out.
Old Sep 14, 2003 | 06:03 PM
MY350Z.COM's Avatar
i know this doesn't help, but i must ask....
why are you going with such a small width?
the small width combined with the high offset will result in a weird stance.
just my 2 YEN
Old Sep 14, 2003 | 06:13 PM
G-Ryder's Avatar
G-Ryder
Well the rims are being sold locally. It's on a IS300 right now. I can always get wider in the back later but I need to know will it fit for now. Thanks in advance.
Old Sep 14, 2003 | 06:14 PM
2003z's Avatar
2003z
assuming you currently have the 18x8 performance wheels:
Your new wheel will have the following chracteristics:
The clearance from stut housing to the inside of the wheel will be 4mm LESS
The outside edge of the wheel will RETRACT in towards the body by 16mm
For $40 a pair, you can get these from www.summitracing.com :
TRD-7069, they are a 1" spacer. the spacer bolts to your hubs, and the wheels bolt to the spacer. 1"= ~25 millimeters, for an effective +15 offset, or
The clearance from stut housing to the inside of the wheel will be 21mm MORE
The outside edge of the wheel will EXTEND an extra 9mm
http://store.summitracing.com/
SUMMARY: It will be fine with a spacer, but not without.
Old Sep 14, 2003 | 06:15 PM
2003z's Avatar
2003z
oh yeah, I have these spacers for my drag wheels.
Attached Thumbnails Help....Can a +40 offset work???-mike-drag-wheel-002.jpg
Old Sep 14, 2003 | 06:34 PM
G-Ryder's Avatar
G-Ryder
So I guess in the front it would clear. Then I would probably just need spacers for the rear? .....Seems like to much trouble do you guys think it's worth it?
hulkout
Tuning
Sep 30, 2015 12:33 PM
