Rust in Open Lugs?
Old Apr 3, 2009 | 03:26 PM
MethodRN's Avatar
MethodRN
For Sale
Default Rust in Open Lugs?
Sup guys, I've tried searching using the tags Rust, Lugs, Open and just can't seem to find any info on how to get rust stains out of my open lug nugs from the wheels studs. I've got Project Mu Lug nuts that have a finish on them and don't want to have to resort to using a dremel. Any help is appreciated. Mods, this may need to moved to the repair/maintanence section.
Old Apr 3, 2009 | 04:07 PM
blktrack350's Avatar
blktrack350
would a rust remover spray like pb blaster damage the outside of the lugnut?
Old Apr 4, 2009 | 06:40 AM
NIZZMO's Avatar
NIZZMO
I had this happen on the inside of my Kic's re40's, I took a some pb blaster and sprayed it on a rag and cleaned it out then some rust preventer on a Qtip (after installed) and put a very light coat on them works great so far.
Old Apr 5, 2009 | 05:52 AM
MethodRN's Avatar
MethodRN
For Sale
Thanks guys. I'll give this a try.
Old Apr 5, 2009 | 01:04 PM
Changvi's Avatar
Changvi
Try some WD-40 inside the lugs; then use q-tip to wipe excess fluid dry. Then re-apply WD-40. I use it on my craft square mirror screws because they are exposed to the element. And WD-40 works great.
Old Apr 5, 2009 | 01:30 PM
r_seng's Avatar
r_seng
I have the same issue, everytime I wash the Z...
Old Apr 5, 2009 | 01:44 PM
terrasmak's Avatar
Never seen a prob with mine, then again quality aftermarket studs don't seem to rust like stockers.
Old Apr 5, 2009 | 06:27 PM
MethodRN's Avatar
MethodRN
For Sale
Will spraying wd-40 into the lugs possibly loosen the lug from the stud?
Old Apr 6, 2009 | 01:28 PM
terrasmak's Avatar
Nope , WD40 is not a lube , and can actually help your lug freeze to your stud over time.
WD actually stands for ??? anyone anyone ?
Old Apr 6, 2009 | 01:33 PM
jdudzik's Avatar
jdudzik
WD stands for Water Displacement formula #40
Old Apr 6, 2009 | 03:25 PM
MethodRN's Avatar
MethodRN
For Sale
Good info guys, thanks!
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
